My speed control when i turn it on jumps 10 mph. I went to Clarks Garage and did what was instructed. I took it apart and cleaned the two wiper strips on the bottom and the 2 little contacts put it all back together and the same results. Got a new(used) unit did the same thing. Is there some other contact that I should be claening or is the computer itself shot.
Thanks for the help George
'87 944na '86 951 |
Uhmmmm are you sure the cable is not binding some where?
I had a similar issue years ago and the cable was not adjusted properly.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
