1984 timing and balance BELTS help
under normal circumstances i would just go for it but after research and reading i'm concerned .
i am what i consider a well above average weekend worrier , ive done rebuilds and MAJOR repairs on alot of cars but the timing belt water pump etc. on my 1984 944 will be the biggest thing ive had to do on this car , seems like theres alot to it and im now scared off , is this ( water pump and new timing and balance belts ) something i CAN do myself DO i really need the p9201 ? any info on specs " how to " or " never do this " kinda stuff would be great . if i didnt poke around the net for info i would already be back on the road , or have a bunch of bent valves by now , but now im looking for some advice and help thanks in advance
jimheinz
man i hope this works
Old 07-07-2005, 08:15 PM
SoCal Driver's Avatar
Just doing the belts and pullies is no biggie. You can replace the water pump without removing the rear cover IF you cut the top half off at the water pump. Then most of the time you will need to replace the balance and crank seals too. This means the entire rear cover needs to be removed.
A flywheel lock is a good idea as you will need to put over 150 foot pounds on the crank bolt to get the pullies off to get to the seal and remove the cover.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-08-2005, 09:57 AM
meister member
speedracing944's Avatar
there is a complete write up on how to do this on www.clarks-garage.com.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 07-09-2005, 09:33 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Check out Arnnworx, buy his tool kit, with the kricket tensioner, balance shaft wrench, flat 27mm wrench and flywheel lock. You won't regret it. Once you're armed with that and a basic set of tools, go to town!
It isn't hard or complicated, just a bit time consuming, and you need to keep your head on straight while you do it, or you might find yourself going back to put things together the right way.
Between Pelican and Clark's Garage, you can and will get through this!
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 07-09-2005, 01:41 PM
