Hi Folks,
On my way back from getting a new fan relay, the car started sputering when I got on the gas and lost power. It seems like it's missing or something, but there's no backfiring or anything. It feels like when you lose a head gasket, but there's no antifreeze coming out the exhaust, and the oil isn't milky, so I'm thinking my timing belt slipped............ ![]() Ideas? This is now my primary mode of transport
-- 1969 Mercedes 280/8 114k miles [RETIRED]1985.5 944 NA just under 300k miles [RETIRED]1972 914/6 190k miles [RETIRED]1997 951 180k miles Last edited by roadierfl; 07-19-2005 at 03:21 PM.. |
Total loss of power or just some?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Some....hard to put a figure on it but I'd say 25%.
It starts and idles without making any strange noises. When I pull on the throttle cable, it goes "prrrp...prrrp...prrrp" instead of "prrrrrrrrrrrrrrrrrrrp" (it's hard to type noises LOL)
-- 1969 Mercedes 280/8 114k miles [RETIRED]1985.5 944 NA just under 300k miles [RETIRED]1972 914/6 190k miles [RETIRED]1997 951 180k miles |
It started happening when I laid on the gas around 3k RPM coming into my street from the stop sign
Check your plugs and plug wires.
Check your distributor cap. Check your rotor. Check for vacuum leak. Check your fuel pressure. There might be more... gb
Good luck, George Beuselinck |
So you don't think it's a timing belt issue? Phew, that's great news
![]() I just checked the plugs, they're all fine, and the wires, cap and rotor are all new so should be ok. Vaccuum leak is something I didn't even think of, so I'll check and see what I can find. If it's not, what else do you think it might be? Thanks for your help, it's trully appreciated
Why do you think the timing belt may have slipped? Is it due for replacement?
Id check the vaccum lines.... when i bought my car some of the lines were leaking/disconnected . After fixing them all up I was very happy with the power the motor was putting out .
'05 M3 - Alpine White '88 924S - Black '91 318IS - Alpine White '88 Honda Hawk '75 Honda CB360 |
Back from Beyond
Here's a thought...has it been raining lots where you are? The reason I ask is that mine did what you're describing (if I understand your symptoms) and it turned out to be moisture in the throttle switch. How does the car run if you disconnect the throttle switch? It's located underneath the throttle body and the connector is easy to get to. Unplug it, see what happens.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
I thought it might be the timing belt because it's the same symptom I had in a Chrysler Turbo a couple of years ago.
The belt *is* due for retentioning Just spoke with the Porsche shop owner I've been buying parts from and pestering with questions like "how do I do this?" and "how do I do that?"- he's a great guy, definately reccomend to anyone in DE/MD/lower PA - Anyway, he said there's no way it could be the timing belt, because even if it slipped 1 tooth, it wouldn't run period, and suggested that the AFM may have an issue. Guess I'll find out in a few mins - have a spare one here
Yes there was a lot of rain a couple of days ago, so I'll be sure to check that out also.
Thanks again to everyone for your help
