I always wanted to make a cam regrind for my '83 944. Is a cam regrind and degree a good idea for a car its spark time is controlled by DME?
1984 Black 944 (w/'83 engine & P/S) 2008 Ford Explorer XLT |
You could do a redgrind and get it back to factory specs or do a performance grind. I have heard bad things about the welded material breaking off after regrinds. I know WEB cams and JM do cams. The whole degreeing in a Cam on our 8v 944 is not doable, You cant get a good spot to run a dial indicator on the lobes because the cam is in the housing, Also you would need a adjustable cam gear to help get it exactly on target. Do a search there is a topic on cam degreeing Im sure you will find helpful. To correct what you said above, When you are degreeing in a CAM it has nothign to do with ignition timing its all valve timing, unless you where worried since the dist. is run of the cam but that is also where a adjustable cam gear would help. Anyway Im sure you would notcie a difference if you swapped a performance cam in.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership Last edited by fast924S; 07-20-2005 at 10:40 AM.. |
Thanks!
Get a later model 944 cam. It has a longer duration on the exhaust than the early (83) cam. Adds a couple of horses.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I got a nice "sporty" cam from WEB cams and now the car has an awesome lumpy idle along with noticeably better performance at higher RPM. I would recommend it just to get the cool idle and sound...of course the added performance is always a plus
1985.5 944 NA -Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam, -Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob. Just Finished: Clutch, flywheel and transmission...and TONS more! |
