cooling fans come on when ac turned on?
I've owned this 84 944 for almost a year and for some reason as soon as I turn on the AC the cooling fans come on and will stay on even if the temp is below the first line, and will not go off until I turn the AC off. The fans operate normally when the AC is not used coming on about 2/3's the way up and shut off at about the first line. All the wiring to both systems seems to be in good shape, so I don't think its a short, maybe in the relays or fuse box? If anyone has heard of this or might know what it is help please, I'm sure this is causing excess wear on my fans. So now I only turn the AC very rarely and not for more than a couple of minutes.
84 944 87 944 |
That is normal. On all cars when the AC is turned on the fans will come on. The AC Condenser needs constant air flow for the AC to work properly
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
yea i was a bit surprised when i found out too...here in nor cal it gets so hot and my A/C's broken...so i just turn on the knob to cool down my engine :-P. i hate watching the water temp go to the 3rd line.
84' 944 |
It's not good to run the AC for an extended period in stop-and-go traffic. That puts an extra load on the idling engine, and it defeats the purpose of using the extra fan to cool the engine down.
Thanks for the info. Wish there was a way to defeat this, but I was thinking of deleting the AC anyways since this my project car.
84 944 87 944 |
Ornery Bastard
The extra fan, as stated, is _not_ to cool down the engine but to maintain constant airflow across the A/C condensor in order for the A/C to remain functional. The additional load is negligible and there should be no effect on the coolant temperature unless you're talking about 120+ degree days and even then it shouldn't take it near the red zone. There are two fans, a low-speed and a high-speed fan, and the A/C should only engage the low-speed fan. The added heat generated by the A/C system is far outweighed even by the low-speed fan. I run A/C a lot in my 951 and even idling in stopped traffic on I-5 it never gets more than a needle-width above the first white tic-mark. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
meister member
use my air conditioning switch to turn on my fans when it is hot out. I turn them on when I am braking or sitting at a stop and go light.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Today's my B-day, btw. Happy B-days are in order, and gifts will be accepted.
Happy anniversary of your first day breathing oxygen!!
Bob S. former owner of a 1984 silver 944 |
