PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
Exclamation The Dangers of the 3-Legged DME Relay
im sort of confused about this topic, i know it is a good fail safe to get you a short distance in an emergency.
but what are you risks you are taking, i heard something about fuel lines bursting causing engine fires, if thats true, what else?
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 08-16-2005, 11:44 AM
So long as the car is running there is no difference. Plug it in and leave it on 20 year old fuel lines and you might get a leak.
An easier field expidient method for a dead DME relay is to remove the cover, and wedge some folded up paper to force the contacts.
Helluva lot asier then monkeying around shorting the pins with wire and all that.
____________________
Why do people spend so much time defending their opinons, but so little time learning and reasoning?
Old 08-16-2005, 12:00 PM
ive never heard of that, does it work? will the car keep running after you take out the key like if you were using the dme jump?
Old 08-16-2005, 12:04 PM
Car won't keep running bt the Fuel Pump will.
Both are only a field expedient method to get home and replace the relay that should have been in your glove box.
Old 08-16-2005, 12:13 PM
SoCal Driver's Avatar
Use pin #86 rather than #30. #86 is switched via the ignition. Gives some margin of protection. Still for $20 you should replace the DME relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-16-2005, 03:27 PM
the dme relay in my glove box is the 3 legged jumper, i have a new one in use right now
[QUOTE]SoCal Driver
i think im going to change my jumper relay to that, so just switch the wire connected from #30 to #86?
.......i hate the dme relay i decided
seems like theres no possible way to surpass it safely
Old 08-16-2005, 08:33 PM
A bit backwards on the logic. For safety you have to use the DME relay. No bypassing it for on the road use.
Old 08-17-2005, 07:21 AM
yeah i know its for safety, i just wish they didnt wear out or stop working for no reason.
Old 08-17-2005, 07:27 AM
As I've reported; I've only replaced mine ONE TIME in twenty years of ownership.
I wish a lot of things didn't wear out.
Old 08-17-2005, 07:31 AM
