Coolant question
I just had a shop do a cooling system flush.
They assured me they know what they are doing as far as a Porsche goes (84 944). They put in the orange stuff so I assume it's dex-cool. Wether it was phosphate free, I don't know. But I now have a leak. And it's coming from behind the cover so it looks like it's probably a bad WP. Could they have used the wrong stuff and messed it up? |
Wonder what they flushed it with......Years ago I did that to an old Ford of mine. Followed directions I thought. Ended up replacing freeze plugs and the heater coil. Since that bad experience I never flush with anything other than water.
I switched to the orange stuff a number of years ago in my 944T. It leaked at hose fittings for a while but eventually quit. And I do have coolant in it.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
Coolant liquid is notorius for finding leaks - more than water. Do you have the new style water pump or still the old pump?
1983 944 RHD Original. Uses all my spare cash! 1947 Morris Sold 1972 Benz Sold 1975 Benz Sold 1976 Benz Sold 1977 Benz Sold |
But, I'll get it to a Porsche shop and have them fix it and check the belt, roller, etc.... |
do they work on foreign cars, any in the parking area.
shops, claiming to know what their doing has cost folks a bunch. anti-freeze will leak where water won't. don't know what year your ride is but i thought i had a bad cap on the old 84944, replaced it with one for a later model, which runs higher pressures and had a leak about where you describe. it turns out the old cap was ok, put it back on, lower pressure cap and the leak went away.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
The shop I am taking it too is one recommended on Clarks-Garage.com (Currey's) so I trust it.
Mine is an 84 944 N/A and it's leaking from behind the timing belt cover somewhere. It's leaking alot too. This is just after a system flush so the flush probably cleaned out some corrosion that was plugging a leak or something. |
disgusted
Michael Manning 95 Independent Fabrication Deluxe You are not what you own! |
