Coolant Leak
Since this past friday been leaking a lil coolant.
Here are my the specifics: * Only when hot/pressurized * Localized from what looks like lower radiator hose after the clamp nearest to radiator (hose from pump to passenger side radiator) * Clamp is extra tight, still drips * Radiator and hose are both new as of August '04 If i release the clamp some to adjust the hose while system is cold it stars flowing in proportion to how loose clamp is. Whats next?
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
is it possible that you have the clamp too tight and are cutting into the hose or possibly cracked the hose fitting on the radiator?
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
both are i suppose. which would tend to give first from normal driving?
Usually the hose.
AFJ
promising. thanks for the help.
