What can i tune up on my 944?
I think my car needs a major tuneup. Im currently getting 17mpg, using premium gas and driving it softly. Maybe 4 months ago i replaced the air, oil and fuel filters. Recently i put in new spark plugs and transaxle fluid. What else can i do to fix my sick car? Its an 83' with about 70k miles.
I purchased it in fef of 05' and it had been sitting for awhile. But ive been using it as a daily driver since i bought it, and have put about 5k miles on it.
Old 10-03-2005, 06:42 PM
That Guy
Techno Duck's Avatar
Ignition Wires
Distributor Cap
Ignition Rotor
Fuel Pressure Regulator (only if your car is running rich)
O2 Sensor
Vacuum lines
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-03-2005, 07:16 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Okay. First of all "Premium" is just a marketing ploy by the gas companies. The octane of gas has nothing to do with quality. The octane refers to knock rate -- the only reason you should run 93 octane gas if your car doesn't call for it (I believe 87 octane is fine for a stock 944) is if you are getting knocking/pinging from the engine at high revs. Otherwise you are just throwing money away.
The standard tune-up is cap, rotor, plugs, oil, and filters. Ignition wires might be needed if yours are old and worn.
Test the 02 sensor; unplug it and see if the car runs better with it unplugged. Is the car running rich (gas smell even at idle)?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 10-03-2005, 07:35 PM
