-   -   left click (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/244657-left-click.html)
hpaulb 10-06-2005 10:00 AM
left click
I hear a click every right turn? It just went through a safety check and they didn't say anything was wrong with the suspension? How is the easiest way to check what's loose/causing it?
CJFusco 10-06-2005 10:02 AM
Usually a click while turning points toward a wheel bearing, but it really could be a number of things... hell, a loose bolt or lug nut, or even a loose center cap could cause strange sounds. Is it coming from the front? Rear could also point toward CVs...
Panzer909 10-06-2005 01:11 PM
I'm thinking CVs too. Is it a single click for every turn, or is it more of a TINK TINK TINK throughout the turn?
Are my sound effects accurate?:)
sca037 10-07-2005 05:09 AM
If it is a single 'click' when first turning, another possibility is that it's the door.
My 944 does this sometimes, but I've never investigated as to why it does it........:confused:
Brian
hpaulb 10-07-2005 06:38 AM
It's one click ever right turn. Sounds like its in the left front area but were?
yellowline 10-07-2005 08:02 AM
If it does come from the door, it's probably the crossbar.
To figure this out, I took off the door panel and simulated the conditions where it clicked. All I did was quickly jerk the wheel and correct, on a rural road w/o traffic, of course. With my other hand, I felt in the door. You can feel the crossbar flex.
To tighten this, it requires a 12-point socket. I have a set of 4...6,8,10,12mm...none of them fit. I ended up nearly stripping one bolt trying to get one socker into it. If it's possible to find an odd cheesehead socket, I guess you could try that. I eventually gave up and let the door click.
ronin 10-07-2005 08:57 AM
sway bar bushing. check under the left front of the car to make sure yours hasn't squeezed out of the clip
