Gon fix it with me hammer
svandamme's Avatar
any 924 monsters out there?
who has a souped up 924, pics , specs ? common guys , show us what you did to the stock engine, not looking for transplants, i wanna see how far the stock engine can go and what you guys did to get there..
no offence, but the 924S , that's not what i'm after
turbo's,mmm not really either... it's the 2L N/A 924's i wanna see
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-29-2005, 02:11 AM
svandamme's Avatar
that ain't a 924...it's a 911.. well sort off
but it's definately not a 924... look at the windshield , and the frontwheels are to close to the driver to be a 924
Stijn Vandamme
Old 09-29-2005, 04:00 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
it's not a 911 either, it's a Skoda
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 09-29-2005, 06:51 AM
svandamme's Avatar
impressive, a skoda , that looks sortoff looks like a 911 that sortoff looks like a ferrari something like ish thing
but still no friggin souped up 924
common guys , there must be somebody out there that did something nuts with a 924 ?!? hot cam, and high revs, efi? more displacement?
Stijn Vandamme
Old 09-29-2005, 06:56 AM
I'm currently rebuilding a spare motor I have for my 924, I'll note the parts still in progress for you. I plan on assembling the motor over the winter and having it in the car next summer:
Headwork - European Motorworks "Big Valve" conversion(complete):
- 44mm Stainless Steel Intake Valves
- 35mm Stainless Steel Exhaust Valves
- Port and Polish
- Racing Guides
- RaceSport Valve Springs and Retainers
Cam - Stage 1 (Complete):
- 233 x 470
- this allows me to retain the stock injection
Engine Block (In Progress):
- just a hot tank cleaning and prepping the cylinder walls for pistons, I am not getting too crazy with an overbore or stroker
Pistons (Complete):
- Mahle 9.3:1 euro pistons
Miscellaneous:
- Audi 5000 throttle body - I'm running this on my current setup
- Cat delete - I'm running this on my current setup
So there you go, a pretty basic rebuild with a few minor tweaks. Everything I am doing is pretty much tried and tested 924 2.0 stuff which should show a few small gains. Base is 125hp with the euro pistons, the head work, cam and miscellaneous items should yeild a few more horses. Some of the other guys on 924Board.org have done some much more wild things, like supercharging....
Old 09-29-2005, 08:30 AM
The current issue of Excellence magazine has a nice article about the 924 gts. If I recall correctly the hp is around 275, that thing must be a rocket...
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 09-29-2005, 09:11 AM
Send a message via AIM to AznDrgn
Check out 924.org, there are a lot more 924 guys there and they have tons of pics of cars running all sorts of ****.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 09-29-2005, 09:20 AM
fast924S's Avatar
Send a message via AIM to fast924S
Wilk your crazy, where to you find all theses insane pics. Dont tell me you have that car at ur house so u can burn some chips for it HAHAHA
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-29-2005, 02:22 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Any idea what that GTS sold for on eBay? I missed the end of that auction
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 09-29-2005, 02:38 PM
svandamme's Avatar
i was just thinking , the green turd needs a some rust panel replacement and a new paint job.. might look into some CGT body kit
but it would be a horrible poser car if no power is under the bonnet
looks like 150 is the top for the N/A 924.. and only at great cost
i'm not really into turboing...
guess i'll stick to the 911 for the real power fix and leave the green 924 alone, it's a good beater...maybe eventually fix the rust , with FG fenders, normal 924 size then ... if you can't add power... might as well loose weight , no?
Stijn Vandamme
Old 09-29-2005, 02:39 PM
disgusted
THE manning's Avatar
I'd like to see the same thing. I want to see somebody accurately replicate the 933 (D Production) motor and detail what they did. Some of the info I have is accurate as to what was done, but some is vague and hardly credible. I believe it was a standard 924 block with a tweeked 931 head. It had Kugelfischer fuel injection typically, or some folks ran Weber TBs. That info is all easy to find. On the other hand pistons and rods are a mystery. I have read they were possibly as weird as Cossie Vega slugs. I have also read they were pretty much whatever the builder could get to work and that is why there isn't much info about them. If Porsche built the first 16 in the factory, why aren't the part numbers listed anywhere? I have also read in a few places that the head wasn't a run of the mill 931 head, but don't have specifics on that.
In any event, the motors were not likely streetable, porbably had a lumpy idle, but made a lot more HP than stock, like close to 180bhp which is what, like 50 or 60 more than stock.
Michael Manning
95 Independent Fabrication Deluxe
You are not what you own!
Old 09-29-2005, 02:41 PM
svandamme's Avatar
why would they have a lumpy idle? the mechanical injection is pretty good gear if well tuned... way better than CIS , or even early EFI...
my 911 doesn't have a lumpy idle either, that's also high strung engine although it is a flat engine , so it is more balanced , but that's more a vibration thing , i don't think that has much to do with how well they idle
Stijn Vandamme
Old 09-29-2005, 02:44 PM
svandamme's Avatar
http://www.924.org/models/924Dpartslist.htm
http://www.924.org/models/924D933.htm
Stijn Vandamme
Old 09-29-2005, 02:49 PM
disgusted
Yeah, I've seen all that, as well as many Panarama and Excellence articles about the 933. If you look at the links you sent you will see there is nothing listed, at least that I could find, regarding pistons or connecting rods. The only info related to them at all is a listing for rings.
It may have a lumpy idle due to the cam profile. The Kugelfischer FI has nothing to do with it. It also may require better than pump gas since the compression ratio is kind of high.
Michael Manning
Old 09-30-2005, 07:16 AM
Geo31's Avatar
Here's a pair of DP 924s. I shot this photo at Mid-America Raceway in Wentzville, MO in 1982.
George Roffe
Old 10-01-2005, 05:44 PM
Geo31's Avatar
It probably has as very high idle as well.
George Roffe
Old 10-01-2005, 05:46 PM
jluetjen's Avatar
They really had get very radical with the cam to get the max out of the engine, because the Haron style head (where the chamber is in the piston) really can't be made to flow very well. The problems are...
1)That the valves are too small
2)You can fit larger valves, but then they get shrouded by cylinder walls.
3) You can increase the lift and duration (which is what they did in the DP 924's), but you find that it's hard to keep the CR up and still have adequate flow for inertia tuning during overlap.
The result was that they got a measely 180 HP out of a 2 liter motor, and a very narrow power band to go with it. Compare that with a 2 liter 911 motor which got 160 HP in normal S trim, and could be pumped up to a fairly brawny 210-220 HP with a rev range from 5000 - 8000 RPM.
They guys who turned the 924 into a D-Prod winner really did manage to make a "silk purse out of a sows ear".
BTW - One of the "Factory" 924 DP cars still runs in SCCA GT3 regionals up here in New England.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-06-2005, 01:49 PM
924RACR's Avatar
But with the 931 head, the CC is moved into the head - not entirely, perhaps, but somewhat.
I can say for sure that if I were looking to do a hot 924 NA motor (or turbo, in fact, which I will) that I'd use modern EFI. Wouldn't have instantly made that 933 motor streetable for some of the reasons noted above, but would definitely make it a lot more manageable. I'd certainly choose that over carbs, and carbs over trying to replicate the Kugelfischer injection. Just not worth the hassle any other way.
But hey, motor technology has improved a lot in the past 30 years - and a good portion of those improvements could in fact be incorporated into the 2.0L for a decent streetable motor.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 10-11-2005, 07:33 AM
