armandodiaz's Avatar
A/C blows warm at idle
Any ideas?
I have replaced the compressor because of a leaking front seal. I have fully evacuated the system for an hour but it blows warm until I get it up to 3500RPM then it starts to cool.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 10-12-2005, 10:09 AM
Ornery Bastard
Re: A/C blows warm at idle
Originally posted by armandodiaz
Any ideas?
What's the charge level of the refrigerant? What's your low-side PSI at idle?
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 10-12-2005, 11:01 AM
I don't remember the pressures off-hand. I am wondering if I put too much oil in when I installed the new compressor. Is there anyway to tell? If I remember correctly I put 8oz in the compressor and about 1 oz in the dryer.
Armando Diaz
Old 10-12-2005, 11:23 AM
bearone2's Avatar
check the hi and lo pressures when running and the fan on 4.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-12-2005, 03:25 PM
Did some diagnosing this weekend.
The pressures are at 80 low 90 high. When I rev it up the pressure goes 40/120.
There seems to be knocking at the compressor (reman compressor, 2 months old).
The oil that came out when I took my hoses off, was black.
Armando Diaz
Old 10-17-2005, 05:19 AM
Ornery Bastard
Holy crap! 80PSI low side?! You're about 55PSI over-charged.
Old 10-17-2005, 07:28 AM
I had that on my mind, until I heard the compressor knocking. Where is the expansion valve located?
Armando Diaz
Old 10-17-2005, 09:27 AM
When idling, low/high side should be about 40/150 psi with compressor engaged and cooling fans running.
When reved, low/high should be about 30/200 psi.
Your compressor is shot! might as well replace txv and drier and flush system before installing new components.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-17-2005, 10:13 AM
R134a
Armando Diaz
Old 10-17-2005, 05:02 PM
Location of components:
Expansion valve in front under the fresh air blower below the windshield.
Not sure if you can pull the expansion valve sensing bulb which is clipped to the coil return line.
Old 10-18-2005, 02:43 AM
So how do I get to it?
Do I get it from under the hood or under the dash?
BTW I don't think it matters but I didn't mention that it's an 87na.
Armando Diaz
Old 10-19-2005, 03:45 PM
The rebuilder is exchanging the compressor, but I'm not taking any chances and also replacing the ex-valve and dryer. I'm also going to try and clean the system with brake cleaner and an air compressor.
Armando Diaz
Old 10-20-2005, 05:06 AM
schmedes1's Avatar
That's a good move. Anytime the compressor gets changed, the rcvr/dryer (accumulator) and exp-valve (o-tube) should also be replaced for sure. I would suggest you find a proper a/c flush that is compatible with the refrigerant you intend to fill with and blow it through the pipes while the compressor and R/D are out. Brake stuff is very harsh and could hurt your o-ring/seals, creating a micro crack and a mystery leak somewhere down the road.
1989 944 Turbo (100% stock and restored)
1996 Mustang Cobra - Track Ready via Griggs Racing
Old 10-20-2005, 07:46 AM
Thanks for the advise I'll stop by the local parts place and see what they have.
So, nobody has told me where to locate the exp-valve? From the pic it looks like I should go from under the hood.
Last night I took my glove box off and all I could see was the heater core.
Armando Diaz
Old 10-20-2005, 07:52 AM
schmedes1's Avatar
I have never had to replace mine (yet). BTW, the evaporator is always outside of the heater core from the perspective of the passenger compartment. You were probably looing at the evaporator, meaning that the exp-valve is to the right & slightly above. The most direct way to get to the exp-valve is from the cowl of the engine compartment. It is on the left (passenger side) of the blower/evaporator assembly. Of course, that is a lot more work and disassembly. Hopefully someone with more practice can fill in the blanks.
Old 10-20-2005, 07:58 AM
The pic is looking from the engine compartment plastic cowl just below the windshield beside the battery..
You may need some crawfoot wrenches to get it out.
Old 10-20-2005, 12:32 PM
You can also buy flushing solvents and kits from an air-conditioning supply house like CC Dickson or at auto air-conditioning shops.
Old 10-20-2005, 12:34 PM
