-   -   A bit Ticked... please read (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/246593-bit-ticked-please-read.html)
ike229 10-17-2005 07:31 PM
Well, i finally got the starter motor i won off of ebay and installed it.
Before bidding on the motor i knew that just any starter wouldnt work, and that some starters (non-944 starters) would crank the motor backwards... Which is why i only placed a bid after reading that it was a 944 starter, and had been used for one month.
So i got it all in, cranked the motor.... no start... so i grew suspicious. I popped her in first gear, and cranked her... and sure enough the car went backwards.
the auction is here
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8004570828&sspagename= ADME%3AB%3AEOIBSAA%3AUS%3A11
So im looking for advice....
1) theres no way i could have possibly wired it backwards... right? It is cranking.
2) Has this done any damage to my car?
3) What kind of action should i take against the ebay seller?
AFJuvat 10-17-2005 07:47 PM
No way you could have wired it backwards
Damage: Possible - it is possible for the belt to jump timing when run backwards
Full refund - you don't have much recourse other than that.
AFJ
Britwrench 10-18-2005 09:07 AM
Good way to waste time and money......
ike229 10-21-2005 05:50 PM
Ok, I got a real starter from paragon and it is installed.
The bearing on my last starter was the issue.
Now **sometimes** when i start my car, i get a different kind of grinding sound... it seems when i start my car with the radio on it always happens. So this leads me to believe its a bad connection on the starter.... almost sounds like the solenoid isnt fully engaging. Ill check it out more closely tommorow, but any thoughts?
rb101 10-22-2005 05:46 AM
how do the teeth look on the flywheel?
Dougster 10-22-2005 07:50 AM
That is too bad, I wonder why anyone would buy anything from ebay to begin with?
Good luck/skill!
ike229 10-22-2005 06:39 PM
I decided to start from scratch, so i took the motor off..... and put it back on. Problem Solved. The only thing i can think of... is that i may have reversed the 2 bolts that hold the motor on. Pretty stupid move on my part... but in the whole fiasco i have gone through I may have very possibly done this. Also, the motor, and flywheel arent damaged.
