Send a message via AIM to ike229
Angry A bit Ticked... please read
Well, i finally got the starter motor i won off of ebay and installed it.
Before bidding on the motor i knew that just any starter wouldnt work, and that some starters (non-944 starters) would crank the motor backwards... Which is why i only placed a bid after reading that it was a 944 starter, and had been used for one month.
So i got it all in, cranked the motor.... no start... so i grew suspicious. I popped her in first gear, and cranked her... and sure enough the car went backwards.
the auction is here
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8004570828&sspagename=ADME%3AB%3AEOIBSAA%3AUS%3A11
So im looking for advice....
1) theres no way i could have possibly wired it backwards... right? It is cranking.
2) Has this done any damage to my car?
3) What kind of action should i take against the ebay seller?
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 10-17-2005, 07:31 PM
AFJuvat's Avatar
No way you could have wired it backwards
Damage: Possible - it is possible for the belt to jump timing when run backwards
Full refund - you don't have much recourse other than that.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-17-2005, 07:47 PM
Good way to waste time and money......
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-18-2005, 09:07 AM
Ok, I got a real starter from paragon and it is installed.
The bearing on my last starter was the issue.
Now **sometimes** when i start my car, i get a different kind of grinding sound... it seems when i start my car with the radio on it always happens. So this leads me to believe its a bad connection on the starter.... almost sounds like the solenoid isnt fully engaging. Ill check it out more closely tommorow, but any thoughts?
'88 924S - Black
'88 Honda Hawk
'75 Honda CB360
Old 10-21-2005, 05:50 PM
how do the teeth look on the flywheel?
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 10-22-2005, 05:46 AM
That is too bad, I wonder why anyone would buy anything from ebay to begin with?
Good luck/skill!
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 10-22-2005, 07:50 AM
I decided to start from scratch, so i took the motor off..... and put it back on. Problem Solved. The only thing i can think of... is that i may have reversed the 2 bolts that hold the motor on. Pretty stupid move on my part... but in the whole fiasco i have gone through I may have very possibly done this. Also, the motor, and flywheel arent damaged.
'88 924S - Black
'88 Honda Hawk
'75 Honda CB360
Old 10-22-2005, 06:39 PM
