help
The other day i was driving and i was at full boost in 3rd and when i shifted to 4th the car just started racing so i went to 5th and it started moving. Then i went home and bled my slave and master better thinking that may have been an issue since i just replaced them and the pedal is stiff. So i go out again today to test it and again im at full boost in third and didnt even get to shift it to 4th before the car just started bucking hard. I dont know how im gonna fix this because it only acts up once in a while. My clutch also grabs very high but always did. Can a clutch make the car buck when its fully in gear already? And are 944 clutches supposed to grab all the way at the end?
winter-hater club member
huh??? what was the question?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Burn the fire.
Is it a dying rubber center clutch?
Sounds like you have boost surging issues...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
i dont think turbos have a rubber center
Super Moderator
could be the cycle valve.
is the car fully stock?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
the cycling valve is long gone, but I talked to LR today and they think its the clutch, pp, and all the associated bearings
