2 fans?
hey guys a quick question. i was wondering how to test if the first fan works? I kno that when my temp gauge hits 3/4 mark, the large fan turns on.
2nd...does cleaning ur radiator (straigthening fins and taking out stuck pebbles) help overheating problems?
84' 944 |
my rad is riddled with pebbles - and never goes above the first line during regular driving.
an overheating issue might be caused by one of those pebbles causing a leak in your system - how's your rad fluid level?
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Dog-faced pony soldier
I recently installed a new radiator in my 951 and noticed a perceptable difference in operating temperature. Might've been the new radiator, or the cooling system flush I did at the time, or the fact I'm now running pure H2O & water wetter. Or a combination.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
my radiator levels fine and there are no apparent leaks.
im running the same as porsche o phile, water and water wetter. yea during normal driving it stays below 2, but stop and go is horrible and brings my thermo to the 3/4
84' 944 |
Wow you really are having problems with your cooling system huh. When your car is off, try spinning your fan blades by hand to makes sure they spin freely. If one doesn't move or is very difficult to move, the motor is probably toast. As far as hitting the 97 degree mark, it seems to be very common on the early cars. The stock thermofan switch tells your fans to turn on at 92 degrees, and sometimes the engine can get a little hotter before this happens making it get close to the 97 degree mark. If you only have one fan working and you are in traffic, it will be much harder for your car to bring it back down below 87 (or 89 I cant remember) where your fans turn off. If you drive in traffic a lot and live in a warmer climate, you could consider putting in a low temp thermofan switch and thermostat. If your thermostat is bad as was mentioned in your last post, your car will not be able to cool down easily as your coolant will not be circulating at the proper temperature. If it opens up at too high of a temperature, your car will be operating at a higher temperature than it should. Are you still having the low temperature issue that you mentioned in your last thread?
'84 944, '05 GTO |
yea like in the mornings, i drive directly to school not much stopping, if there is, its just a stop sign. the thermo never goes above the middle of the left box (very cold). even during warm days when im constantly moving, it usually never goes above the first box, but stop and go traffic jumps my thermo really fast, and my aux fan is constantly turning on.
how much are new thermo fan switches? thanks
84' 944 |
I really dont think that is your problem. I would be on top of checking out my fans and that thermostat if I were you.
'84 944, '05 GTO |
okay thanks
84' 944 |
David Alonso De La Vega Tapage Panama 944 Turbo |
so if my engine doesnt warm up when im moving constantly..u guys think my thermostat is broken?
84' 944 |
Make sure the system is bled properly also. warm up the car and crack the bleeder open just a little and make sure it's getting all liquid and no air out before you close it again.
The thermostat is a PITA to change. The snap ring is big and tough to work with. Use a 90 degree end snap-ring pliers to get it off and just have at it cause it's a stubborn thing! When you replace it, go with a 160/180 degree unit. Lowest temprature one I found was at NAPA and it works great - temps stay below 1/2 on the hottest days!
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
does it hurt my engine if i have a faulty thermostat?
84' 944 |
not unless you're running too hot
by bleeding the syestem do you mean opening the coolant cap just a little?
83 944na |
You must do that with the engine at normal temp running and with the proper bleed fitting ...
'84 944, '05 GTO |
