ness's Avatar
non-running 944 question
I am interested in buying a 944 that has not been driven for 3 years, and will only start with starting fluid. Before that it was running fine, and had all its servicing done up-to-date. I am hoping it basically needs a new battery and spark plugs, but can anyone suggest anything else likely to need doing (e.g. the seller mentioned the injectors may be blocked), so I can go prepared?!
Cheers
Ness
Old 11-01-2005, 08:00 AM
winter-hater club member
nynor's Avatar
after it starts with starter fluid, will it stay running?
"COOL PRIUS!" - Nobody Ever
Old 11-01-2005, 08:13 AM
vott does ziss do?
ronin's Avatar
broken record: belts
Old 11-01-2005, 08:35 AM
That Guy
Techno Duck's Avatar
A car that has not been driven for that long of a period will need a new timing belt and balance belt at the least. The service interval for these is about 3-4 years depending who you ask. How much are you looking to get the car for? A car that has been sitting that long can have alot of problems with leaks, dried out rubber parts, tires which may not be good anymore...etc.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-01-2005, 08:48 AM
ness's Avatar
Thanks for the comments. Timing belt was replaced shortly before seller stopped driving it - would it still need replacing? Seller is only asking $1000...
Meaning of life = porsche + rugby
Old 11-01-2005, 09:14 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Yep, replace it anyway. It's age, not wear at this point.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 11-01-2005, 09:19 AM
seaboltman's Avatar
Yes replace the belts, They have since dryrotted and will need to be replaced... unless you want to risk it and have to get a new head/rebuilt head if it breaks. its 60k miles, or 3 years, whichever comes first. Trust me, the last thing you want to take a chance on with this engine is the timing belt.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-01-2005, 09:22 AM
Send a message via AIM to AznDrgn
As far as not running it's probably a bad DME relay or fuel pump.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 11-01-2005, 09:46 AM
That Guy
What is the mileage on the car? $1000 seems alright, but like many others have said before me "There are not many things more expensive than a cheap Porsche". Just be very wary of this car.
Jon
Old 11-01-2005, 09:47 AM
ness's Avatar
168k. Anything else visible to look out for when checking it over?
Cheers
Ness
Old 11-01-2005, 09:51 AM
Eldorado's Avatar
tires.. if it hasn't moved - they could be warped and could potentially blow when they get hot.
was the gas drained? or did it sit for that time with a full tank of gas?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-01-2005, 10:55 AM
ness's Avatar
The gas was not drained - is that likely to cause problems?
Old 11-01-2005, 11:37 AM
Eldorado's Avatar
it could...
corrosion in your gas tank.... that might actually be why the car isn't starting...
were any of the other liquids drained out? oil? coolant? obviously all of that would need to be flushed before you drove it...
Kyle
Old 11-01-2005, 01:02 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Go out there with the troubleshooting guide from Clark's garage.
$1000 sounds alright if it's mechanically sound(ish). For that price, I'd take a pretty rough example
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-01-2005, 01:46 PM
