-   -   Dumb Part # Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/249091-dumb-part-question.html)
livewirevoodoo 11-01-2005 04:36 PM
Looking for part # for the 3-way vaccum tee connectors. Kinky, i know.
Also... If using the off the shelf silicone hosing, how do I connect to the tees if they are constructed for the hard plastic lines?
AFJuvat 11-02-2005 05:51 AM
Leave a little stub of hard plastic line - then sip the silicone hose over that.
928.573.727.02 They are about $9.50 each.
AFJ
Brando 11-02-2005 08:32 AM
hit your local home depo for those small plumbing t-fittings.. those are cheaper and hard plastic as well... if you're a CSOB like me...
livewirevoodoo 11-02-2005 08:50 AM
thanks for the tip. using your CSOB method will i still have to reuse a portion of the tiny hard plastic lines to fasten the hoses to, or are the plumbing t-fittings sized to mate to the smaller diameter hosing?
legion 11-02-2005 09:51 AM
Lindsey Racing has metal T connectors for $2.50 a pop.
