livewirevoodoo's Avatar
Dumb Part # Question
Looking for part # for the 3-way vaccum tee connectors. Kinky, i know.
Also... If using the off the shelf silicone hosing, how do I connect to the tees if they are constructed for the hard plastic lines?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-01-2005, 04:36 PM
AFJuvat's Avatar
Leave a little stub of hard plastic line - then sip the silicone hose over that.
928.573.727.02 They are about $9.50 each.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-02-2005, 05:51 AM
Burn the fire.
Brando's Avatar
hit your local home depo for those small plumbing t-fittings.. those are cheaper and hard plastic as well... if you're a CSOB like me...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 11-02-2005, 08:32 AM
thanks for the tip. using your CSOB method will i still have to reuse a portion of the tiny hard plastic lines to fasten the hoses to, or are the plumbing t-fittings sized to mate to the smaller diameter hosing?
''87 944na 85k
Old 11-02-2005, 08:50 AM
Cars & Coffee Killer
legion's Avatar
Lindsey Racing has metal T connectors for $2.50 a pop.
5 liters of VVT fury now
-Chris
Old 11-02-2005, 09:51 AM
