J1NX3D's Avatar
Question Rear sway bar?
hello,
can i easily upgrade my 14mm rear sway bar to a 18 or 20mm 951 rear sway bar? if so, for the a combo, what would be a suitable sized front sway bar?
i have an '80 924 turbo with early style 924 front sway bar and pre 1985.5 style 924/ 944 style rear sway bar.
TIA!
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 11-05-2005, 05:30 PM
entertaining the idea
UconnTim97's Avatar
Posted on another line
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 11-05-2005, 08:31 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Yup, everything bolts right in.
You might need new hanger bushings, depending on how much bigger you want to go
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 11-06-2005, 08:40 PM
J1NX3D's Avatar
if its a 18 or a 20mm, what would be a suitable size for the front?
- 6 spd/LSD
Old 11-06-2005, 08:51 PM
That Guy
Techno Duck's Avatar
There is no factory 20mm bar, your choices for rear bars are 14mm, 16mm, 18mm and a 19mm adjustable bar.
I would base my decision on the front bar based on what the factory used. So with an 18mm bar i would stick with the following front sizes,
23mm
24mm
25.1mm
25.5mm
You should select which one based on your preference. I would personally go with a 25.1mm front or 18mm rear. That is the same setup used on the later '87+ 944 Turbos. Those are all the front sizes that the factory used with a 18mm bar. You can see a indepth chart here,
http://www.tech-session.com/kb/index.php?page=index_v2&id=23&c=4
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-06-2005, 09:02 PM
J1NX3D's Avatar
ok, the guy whos sending me the rear sway advertised it as a 19mm but i think it could be an 18 as he has an '86 turbo. hes just agreed to sell me his front sway bar when he upgrades in a few months time, he has a 24mm front bar.
cheers
for your help guys, and that chart! Awesome!
- 6 spd/LSD
Old 11-06-2005, 09:18 PM
Writer/Teacher
CJFusco's Avatar
cheers
Could be aftermarket. I have a rear bar that (I think) is aftermarket... measures 19mm across.
The front-rear bias will affect the oversteer/understeer characteristics on your car. That being said, I am running a 26.8mm front bar with the 19mm rear and don't notice any unwanted understeer. Might make itself seen on-track, however...
Old 11-07-2005, 07:56 AM
That Guy
The only 19mm bars from the factory were 3-way adjustable. You can tell from the 3 mounting holes on the bars endlinks. You need to take into consideration the bar is painted with black paint. That may throw off your measurements slightly.
To my knowledge there is no aftermarket 19mm bar. Aftermarket sizes start at about the same size as the smallest front stock diameter bars... 22mm! A rear bar that large will need to be offset by the huge aftermarket sizes of a 30+mm front bar.
Jon
Old 11-07-2005, 12:22 PM
Writer/Teacher
CJFusco's Avatar
yeah, it may be the paint throwing off my measurements
Old 11-07-2005, 05:51 PM
