my bad injector pics
the first 2 pics are of the same injector. The other is of a clean injector. 3 seem fine, but the other seems a bit gunky and leaky. Im going to send them off to have them cleaned and flow tested. This is probably the cause of my erratic idle, surging and hesitating, poor fuel economy, and exhaust smell. Hopefully $60 will do the trick. By the way, which injector would it be, that leaks? If you were to stand by the quarter panel passenger side and look from left to right..would it be 1-4. If so injector #2 is leaky. I know the firing order is 1-3-4-2.
Old 11-04-2005, 08:30 AM
Zero10's Avatar
Send a message via ICQ to Zero10
From how I understand what you're saying, it would be injector #3. In our cars, the cylinders are numbered from front to back
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-04-2005, 09:37 AM
Details are difficult to see due to poor focus.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-04-2005, 10:29 AM
sorry...my camera came free with some printer and its about the size of my palm. You get the gist of it though come on, dont be arrogant. Ill try more later. So you read injector numbers from the outside, in.
1983 Porsche 944
Old 11-05-2005, 06:42 AM
Zero10's Avatar
Injectors are numbered by the cylinder they feed. And in our cars the cylinders are numbered from front to back. I think you understood me correctly.
I've been there with bad digital camera's before.
You definately need to re-seal the injectors, because a fuel leak like that can be really hazardous, although I'm sure you already know that. As for your poor fuel economy and other related problems, this may or may not be the solution, however if your mileage is getting higher (maybe 60k+) they're due for a cleaning anyways.
What else have you done to try and pin down your running problems?
Buy my parts!
Old 11-05-2005, 08:38 AM
Here's what I did while I had the top half of my engine apart.
1) Get an old Tupperware box (enought to hold a quart or so), and drill 4 holes in the cover...the injectors should snap into the hole.
2) Snap injectors in, fill the container with a can of Seafoam injector cleaner, let it sit overnight.
3) Pop the injectors out. Run the injectors by hooking up a 9v battery and cycling cleaner through them. Backflush if needed if you have a vacuum pump like for bleeding brakes.
4) Reseal.
I've noticed my car seems to be a lot lighter on its feet now. When you dig into the throttle from 3500 up, it digs in and goes pretty nicely.
They won't be flow-matched, but for the price, it's worth a try first.
Old 11-05-2005, 01:02 PM
Ive done almost everything within my budget. New air filter. New oil filter (every 2k) . New fuel filter (when i replaced it was literally clogged w/ dirt and other gunk). New spark plugs. New transaxle fluid. Kept good tire pressure. Ran premium gas ( i now switched to regular). Put injector cleaner or gas cleaner in every once in awhile. Just put in a brand new 02 sensor.
When i first got the car last year before anything was done to it i believe it was getting 13mpg. I filled up last night and was getting 20mpg w/ regular unleaded ($2.49/gal!!!)
The guy i bought the car from also put in a real nice and expensive fuel pump, nice wires, etc.
Maybe i have a problem w/ my air flow mass meter. Maybe it needs some adjustment. Im not sure. That one injector just looks bad and i need to get them running properly. I know it may not fix my problems but its a good place to start...again.
Old 11-06-2005, 06:24 AM
That Guy
Techno Duck's Avatar
Depending on how clogged your injectors are now, having them cleaned may yield a huge boost in mileage / peformance or a small one. Either way having them cleaned i think you will see some difference.
I need to have my injectors cleaned also, however i cant afford the week - two week down time involved. Ive been looking around for a used set of late injectors i can borrow or hopefully just purchase cheaply.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-06-2005, 04:28 PM
That one place said turn around time was 1 day.... But im not sure. The witchhunter place that you referred me too.
1983 Porsche 944
Old 11-07-2005, 09:00 AM
That Guy
Turn around time is one day, but you need to take into account the amount of time the injectors are floating around in the postal system. It could be 2-4 days considering they are located in Washington, which is on the other end of the country from NY. Even more so from you being in Florida...thats literally on the other end of the country!
I suppose you could go for the expense of next-day airing it to and from, but that can be pretty damn expensiveat $50 each way! In that case im better off just buying new injectors practically.
Jon
Old 11-07-2005, 11:26 AM
They said they ship it back free..priority, so you just pay to ship it once. It comes out to like $60 plus shipping. I guess it could still take a couple days...damn. But new injectors are at least $100 each.
1983 Porsche 944
Old 11-07-2005, 01:39 PM
That Guy
They will pay for regular priority mail shipping. If you want 2nd or next day air, you still pick up the tab.
Jon
Old 11-07-2005, 01:48 PM
gtroth's Avatar
Another nice thing about WitchHunter is the before/after comparison. Might tell you something. I couldn't resist FedEx both ways which doubled the total cost. But to pull them one weekend and get them back in the next...
1995 993C4 guards red
1988 944S alpine white
Old 11-07-2005, 06:44 PM
They said for $10 extra they will ship back express.
1983 Porsche 944
Old 11-08-2005, 08:11 AM
