P/Steering "morning sickness"??? 1985.5
Any ideas on a power steering that acts like hard manual steering until all is warm? Is there a common fix for this? Just installed rebuilt rack but nothing has changed.
Thanks!
Old 11-13-2005, 06:11 PM
sca037's Avatar
Check that your PS belt tension is correct, and try changing over to synthetic Dexron.
Cheers,
Brian
'85.5 944 (sold and will be missed)
Sport seats, LSD, sways, 7 & 8" Fuchs
Old 11-14-2005, 06:28 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Cold belts slip easier than warm ones. I'd suspect it's belt tension. Usually when they're cold, they don't make a lot of noise when they slip if they're loose. That's where I would start, as already mentioned. If no luck there, check your steering fluid level. I run synthetic ATF, but it's not really necessary where I am, and it's warmer there than it is here.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-14-2005, 08:21 AM
