konan's Avatar
'85 944..fixing fuel pump
It's one thing after another with this car.I was checking a fuel leak and replaced hoses to fuel pump and now fuel pump quit working.....does anyone have any experience opening one up,or ideas about what happened ....or a used pump....
Old 11-14-2005, 03:16 PM
any chance you popped a fuse? do you have 12volts at the pump when starting the engine?
Tom
Early '85 944
Old 11-14-2005, 05:01 PM
I have disassembled a fuel pump..The motor is 95% of the volume, the pump is a tiny thing in the inlet area. Crud gets in the pump mechanism and can stall the motor. A strange design, sensitive to dirt. Cleaning the tank filter and the tank itself can help. Do you have a 12 volt source other than the battery/ Sometimes reversing the motor momentarily will clear it.
As for taking the pump apart and reassembling it, sealing is a problem and in all liklihood will leak!!
Bob S. former owner of a 1984 silver 944
Old 11-15-2005, 07:26 AM
konan's Avatar
Yeah I have 12 volts.....I took it out of the casing and reseated it and it worked for a while,but it also leaked.....so I need to buy a used one if possible..
Old 11-15-2005, 11:23 AM
If you can afford it, I would pay the difference and get a new one. With a used one, you are still in the situation where it could go "bad" at any time. I bought a brand new Bosch that lasted 5 minutes. I returned it and got another one with no hassle. . So much for Bosch quality!! (I hope their woodworking tools are better..I just bought a new Bosch Router!!)
I wonder what the country of origin is on their stuff nowadays?
Old 11-15-2005, 01:12 PM
konan's Avatar
Money would be the problem here,this car is eating me up in parts,but I guess I am restoring it........
Old 11-15-2005, 01:32 PM
I understand.. But Aren't we always being told how reliable the 944 is?
(tongue firmly in cheek)
Old 11-15-2005, 05:55 PM
