HELP: N/A pinging, need help diagnosing...
Hey gang...
I have an '88 N/A that has a pinging issue. Trouble is, I'm not sure where to look next for the possible cause. At moderate/heavy throttle, she pings on 91 octane. The car was pinging when I bought it earlier this year. Since then, I have replaced the TPS, DME temp sensor, O2 sensor, flushed the fuel system and balanced the injectors, and recently replaced the H/G and T-belt (finished that yesterday). The car is still pinging even though the head and pistons are totally clean of carbon deposits and I have brand new OE plugs. I only run 91 octane in the car, and it has a stock chip. The timing should actually be *retarded* slightly since I had 30 thousandths decked off the head to raise the compression, which should actually help fight off pinging (this is not the cause of the pinging, as it was pinging when I bought it months ago). What are my likely/possible causes? Are there any other external sensors I can check/replace, or could the DME itself be faulty? Or is it possible that my FPR/dampener/fuel pump may have an issue causing it to lean out above a certain load or RPM? For some reason I seem to remember messing with the TPS adjustment and having some sort of effect on the pinging, but this was a while back and I cant' recall for sure...was this my imagination or could TPS adjustment be a factor? The car runs beautifully otherwise (aside from needing a waterpump because the bearing is shot and the waterpump pulley wobbles). I just don't know what to check next. If anyone could help I'd appreciate it! Thanks so much!
Sean '88 Porsche 944 '95 Volvo 940T Seal Beach, CA, USA |
...Bueller???
knock sensors?
Jeff Laurence, '87 944S |
maybe throw a bottle of injector cleaner into your gas?
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
1) N/A 8V cars don't have knock sensors!
2) The fuel system is clean enough to eat out of, literally (if you don't mind the taste of gas, anyway). Has no impact on the pinging. I think it's a sensor or computer related issue, but I'm not sure which ones impact ignition timing and/or fuel delivery...ideas???
Just a guess, but a bad catalytic converter will definitely cause pinging. Sometimes you can hear a bad cat rattling from underneath at idle. Also sometimes if you give it a thump with a rubber mallet or something you shouldn't hear any loose pieces inside, but if you do it could need replacement.
85/1 - I just pushed my trip odometer while driving |
Writer/Teacher
Do you have any aftermarket performance add-ons, such as a chip?
Try running it with higher-octane gas and see if the pinging is still there.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Cat is new, stock chip, and 91 octane is the highest we get here.
Ugh! This is really annoying. I'll leave an update if I find anything tomorrow.
Maybe low fuel pressure?
You could also try changing the FQS setting to see if less timing, or more fuel helps. If that helps you could go down that path to troubleshoot the timing/fuel issue - or maybe just leave the FQS set at the position that helps
85/1 - I just pushed my trip odometer while driving Last edited by EA425; 11-20-2005 at 05:33 AM.. |
