Banned
butz's Avatar
Arrow I Question And Apologized!!
First I WANT TO MAKE PEACE WITH EVERYBODY.
Honestly I guess I was a little bad as and bighead !!I understand here all you guys have nice cars and love their cars and that why you take a moment for be in the forum and also I know you guys love all water cool porsches and know alot more about then that that what I do... thats why I have a question I will like somebody to answer it honestly, ,, Like I said my boyfriend have been calling broadfoot racing to order cam for his 944na euro , but nobody answer the phone there!!!, there is another company that make s good quality performance cams for 944na , ?
-what is the name of company?
-usually cost?
-what he will get with the cam?....hp?
-will somebody that alredy had the experience with a performance cam in his 944 na in this forum recommend or not?
Thanks I will appreciated a reply that can clear all my questions above!!!!!!!AGAIN I very sorry a kiss Alina
Old 11-21-2005, 08:12 PM
fast924S's Avatar
Send a message via AIM to fast924S
JM enginering makes the best cames. They go for about $650 I believe. He claims 12-20 bhp depending on the cam used.
Link
http://www.jmengines.com/index.htm
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-21-2005, 08:39 PM
Banned
butz's Avatar
THANKS alot for reply but still need to understand
-hw it works ?I will be a good optin for owner of 944na
-will somebody that alredy had the experience with a performance cam in his 944 na in this forum recommend or not.
-there something else we have to add out of cam to get full performance?
Thanks again??I hope somebody can aswer it......
Old 11-21-2005, 09:19 PM
Ornery Bastard
Throttle cam or actual cam?
Throttle cam doesn't actually add any power at all. Throttle cam just makes the throttle response linear instead of progressive. The stock throttle cam makes the throttle less sensitive just off idle.
Actual cams require you to pull the top of the engine and will change your powerband depending on the specific grind.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 11-22-2005, 04:17 AM
Banned
butz's Avatar
WE ARE ASKING ABOUT REAL CAM CHANGE FOR RACING CAM !!!!
Old 11-22-2005, 03:29 PM
KY944S's Avatar
Dang cool down and take a deep breath .
ok
Probibly the best people to ask would be the people you may be buying the cam from. They would probibly have the best recomendations for installing the cam.
1987, 944S (168,000 miles)..sold
1986, 944na.
My job is a hobby. My 944's are work.
Old 11-22-2005, 03:44 PM
pokey's Avatar
Send a message via AIM to pokey
A MAF conversion would be the single best performance improvement on an NA, and will work well with a performance cam. A good header and freeflowing exhaust will also be a big help with a new cam. Fast924S knows his stuff, and has given you a link to a very reputable manufacturer. For a good description of how they work, and what they do, check http://auto.howstuffworks.com/camshaft.htm
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 11-22-2005, 03:45 PM
Banned
butz's Avatar
WHAT IS A MAF conversion ? WHERE I GET IT HOW IT WORKS?THANKS
Old 11-22-2005, 04:40 PM
KY944S's Avatar
When you type in CAP'S, it looks as though you are YELLING at us. Just a little FYI.
1986, 944na.
Old 11-22-2005, 05:20 PM
KY944S's Avatar
Oh ya MAF conversion. Here ya go.
http://www.promax.uku.co.uk/maf_kit.htm
1986, 944na.
Old 11-22-2005, 05:22 PM
pokey's Avatar
Mass Air Flow. It does away with the AFM (Air Flow Meter) that is a big restriction in the intake. FRWilks is supposed to be releasing a reasonably priced version. Either Wilks or Fast924S can give you a good description of how they work, at least I understood their descriptions in the past.
1956 Ford F250
1955 BMW R69
Old 11-22-2005, 05:26 PM
livewirevoodoo's Avatar
Interesting... Will that play nicely with a Wilks chip?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-22-2005, 05:28 PM
KY944S's Avatar
Not sure on that one. But if FRWilk is making a MAF system of his own I don't see why not. You could e-mail him. Plus if you get the one from Promax it would cost $1098.19 (exchange rate) plus shipping.
1986, 944na.
Old 11-22-2005, 05:36 PM
fast924S's Avatar
OKay this is a little complicated SO im gonna make it easy. MAF= mass air flow sensor. Basicly There is a LITTLE bare wire exposed to the air intake stream. Current is passed threw the wire and the wire is heated to a set temp. As more air flows over the wire the wire cools down and the DME has to put more current threw the wire to keep it at the set temp. So as more air passes over the wire more current is needed to keep the wire hot. The DME watches the current change and knows how much Fuel it needs to add. MORE CURRENT=MORE FUEL, LESS CURRENT=Less FUEL. If you want a more detailed discription you can to a search on the Forum or on the WEB
Most MAF conversions need a custom chip or signal/piggy back unit to make proper fuel corrections. The "simple" DME wont understand the MAF signal. FR-Wilks MAF kit is plug and play due to the fact that it has a build in signal converter so no addtional chip or piggy back unit is needed. My MAF setup is a little different it uses a piggy back unit to message the incoming MAF signal so I can alter the A/F ratio. The best Performance way to do it is make a MAF kit and have custom chips burned for the MAF. I believe guru Racing does that with there MAP conversions and may be able to help you with a MAF conversion.
Yes that MAF kit in the link will Work with the fr-wilk chip. But the FR-wilk MAF kit is cheaper in price and I would trust FR-wilks stuff over any other stuff.
Old 11-22-2005, 06:24 PM
Banned
butz's Avatar
THIS PROMAX SAID IS JUST PLUG AND GO DOSEN;T SAID ANY ABOUT THE PIGGY BACK CHIP?????SEEEMS LIKE ADEAL FOR ME HOW MANY HP YOU CAN GAIN?????NON TURBO CARS ?
AND THS WILK MAF KIT HOW MUCH COST IT IS READY TO GO??
Old 11-22-2005, 07:15 PM
Banned
butz's Avatar
Sorry about caps i had key board set in other language , any way!!
Can somebody let me know in other post about headers I call Jon Milledge he said that msds headers are worst than standar stock porsche headers I want to see If taht is real? If somebody else has msds headers in their 944???
Old 11-22-2005, 07:20 PM
Eldorado's Avatar
Wilk's kit is not ready yet..
that kit that is linked up there ^^^ already has the "piggy back" device included...
"This provides an accurate air mass voltage signal to the SciVision processing computer which then relays a corrected AFM (Air Flow Meter) voltage signal to your car's ECU."
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-22-2005, 08:58 PM
Ornery Bastard
The stock headers and exhaust are very good, they're a very free-flowing design from the factory and it's difficult to improve upon them. I don't mean that they can't be improved upon, but there will be trade-offs.
Old 11-23-2005, 03:47 AM
