liljon's924S's Avatar
Porsche Crest Synthetic Motor Oil
Just wondering if you can switch from regular motor oil to synthetic? My dad said you would need to change some things, is he right? I got a 924S.
Old 12-01-2005, 12:50 PM
winter-hater club member
nynor's Avatar
nope. will work just fine.
"COOL PRIUS!" - Nobody Ever
Old 12-01-2005, 01:00 PM
Z-man's Avatar
Keep in mind, however, that if you switch to synthetic, it may appear that you have developed some additional oil leaks. Actually, you won't develop additional leaks, but since the synthetic oil molecule is smaller/slipperier, it has a way of working through old seals more easily than regular organic oil.
I use Mobil 1 15W-50 synthetic in my 944S2. Year round.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 12-01-2005, 01:31 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Change nothing. Switch.
Settled
There is nothing you need to change to switch to synthetic oil.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-01-2005, 01:56 PM
earlr85944's Avatar
synthetic is definately better than conventional. on higher mileage cars I have seen leaks occur (rear main seal etc) when switching over.
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-01-2005, 10:09 PM
Might I suggest a blend such as Valvoline offers?
Bob S. former owner of a 1984 silver 944
Old 12-02-2005, 06:12 AM
Ornery Bastard
You can suggest that but I don't know why anyone would.
A "Synthetic Blend" only needs to have 0.00000000000001% synthetic content in order to legally be called "Synthetic Blend", a good conventional oil will be better than almost all synthetic blends for much less money. A synthetic blend isn't remotely close to a full synthetic. If you're going to go synthetic, go synthetic.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 12-02-2005, 07:25 AM
Just thought I would make a suggestion. I have used it for years now and have had no problems. Comes out "cleaner" than straight dino oil when changed (although I do change it twice a year). Used it in an old Sundance that burned no oil after 154k miles. To be honest, Valvoline considers their info "proprietary" and will not divulge the percentage of synthetic n the blend though. With older cars, I have had friends that did develop the dreaded "leaks" with full synthetic.
Shows how much I know about oil!!
Old 12-02-2005, 09:48 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Has anyone heard of or used Tufoil (http://www.tufoil.com/tufoil/consintr.html)? A guy I used to work with swears by the stuff, but I haven't heard much about it from anyone else.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 12-02-2005, 10:12 AM
disgusted
THE manning's Avatar
There are a few threads over on Rennlist about this. There is a guy by the name of Doug Hillary there who has worked in that industry since the 50's who has some interesting insite into this topic. Check these two threads for some of the discussions:
http://forums.rennlist.com/rennforums/showthread.php?t=174275&highlight=synthetic
http://forums.rennlist.com/rennforums/showthread.php?t=228065&page=1&pp=15&highlight=synthetic
Michael Manning
95 Independent Fabrication Deluxe
You are not what you own!
Old 12-02-2005, 10:20 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Just to give you guys an understanding of what is in Tufoil:
COMPONENTS Weight %
Petroleum Hydrocarbon Motor Oil 35-40
(This is the base carrier for the additives)
Methacrylate/Vinyl Pyrrolidine Copolymer 25-30
(This is a viscosity modifier and a pour point depressant - gives it some body)
Polyalpha olefin 10-20
(this is synthetic oil - helps it be compatable with synthetics and semi-synthetic motor oils)
Didecyl adipate Dimer Ester 5-10
(This is also a synthetic oil - similar function to the PAO but will also help in removing some deposits)
Molybdenum Di (2-ethyl) Phosphordithlioate 5-10
(this is an anti-wear additive, albeit not the best)
Polytetrafluoroethylene 1-5
(a Teflon like substance - I wouldn't put it in my engine. Flourocarbons do not plate onto metal very well nor do they provide any abrasion resistance)
The question is, should someone use this in their engine or any other lubricated system? Only if someone gave it to you. I would buy it - not that great of a stretch from Slick 50. You are better off with timely oil analysis and a good engine oil and filters (air, fuel and oil).
Michael D. Holloway
https://5thorderindustry.com/
Old 12-02-2005, 11:39 AM
correction - I would not buy it!
Michael D. Holloway
Old 12-02-2005, 11:41 AM
Ornery Bastard
Never, never, never put anything that has PTFE (teflon) into your engine. Teflon is a SOLID, and it is just in suspension. Additionally, it expands greatly with heat and has been proven in governmental tests to clog small oil passages.
Tufoil has a decent reputation because it uses a miniscule amount of Teflon and a higher amount of Molybdenum Disulfide. Molybdenum Disulfide is an excellent lubricant and has been used for years in air-cooled racing applications.
You're better off using Mr. Moly, which is a straight Molybdenum Disulfide additive rather than Tufoil because unlike Tufoil, Mr. Moly has no PTFE in it.
Aaron
Old 12-02-2005, 11:58 AM
Aaron,
There is no Mo2S in that product and I am not sure I would use pure mironized Mo2S either. Great fro greases and open gear lubes and even as a dry film lube. Mo2S is a solid that is difficult if not impossable to keep in suspension. The other moly compound that is considered better would be molybdemum di-n-butyldithiocarbamate at a small percent (maybe 1/2% by weight). The stuff is expensive and at somepoint the more that is put in just doesn't get plated anyway. That is real good in oils.
Michael D. Holloway
Old 12-02-2005, 12:10 PM
and I agree, teflon is good for a mold release or to spray on the head of your boat/camper so you don't have ***** stains in the bowl. As a lube additive in oil? Nope. Stupid.
Michael D. Holloway
Old 12-02-2005, 12:12 PM
Thinking it through even further, the Molybdenum di(2-ethylhexyl)phosphorodithioate is called Molyvan L and the Molybdenum di-n-butyldithiocarbamate is called Molyvan A. Depending on the rest of the additives in the oil, they two are actually pretty similar. If the %concentraions mentioned by Tufoil are correct, that stuff muct go for $15 to $20 a quart! Or they are lying. If both are true, I just found a new supplier for Molyvan L!
Michael D. Holloway
Old 12-02-2005, 12:27 PM
livewirevoodoo's Avatar
About time someone got around to posting a thread about dino vs. synthetic oils.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 12-02-2005, 01:33 PM
you'z gots to hang over at the 911 techno posts more. That subject has been put near exhausted!
Michael D. Holloway
Old 12-02-2005, 01:35 PM
seaboltman's Avatar
I got this link off another forum I frequent. Didnt get a chance to read it but ill cross post it anyway, so you guys can read.
http://www.sportrider.com/tech/146_0308_oil/index.html
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 12-02-2005, 02:10 PM
Excellent article.
Old 12-02-2005, 02:25 PM
