LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Sweet! You and your car are an inspiration. Another argument at just how ahead of it's time this car design truly was.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 12-18-2005, 11:29 AM
Comeau Racing
Louie! You back in San Dog?
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 12-18-2005, 12:32 PM
lousailor's Avatar
Tim,
No man, just forgot to update my info. I'm settling into the seasons of the East Coast here in Virginia. I try to keep up with the local AX scene, but the Navy has me in and out for the next year or so. How are things out West. I hope the Spec Racing is coming along.
Louie
'76 924 - Long Gone
- Mario Andretti
Old 12-19-2005, 02:27 PM
Comeau Racing
Mr. Partida,
Thanks for asking. The 944 spec scene is growing too fast for me to memorize all the new guys!
We're trying to get 944 spec groups started on the East Coast, too. If you're near a NASA chapter, post to their website, go to their races, etc. talk it up, ok? We hope to have enough cars to have a National runoff in NASA soon.
PCA since 1985
Old 12-20-2005, 08:27 PM
will944's Avatar
Send a message via AIM to will944
Great project!!!
How did you hook up the speedo and RPM gauge?
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 12-21-2005, 05:27 AM
lousailor's Avatar
The Tach is stock (elec), but I'll have to hook the late model speedo pick-up to the tranny when I finish.
Louie
'76 924 - Long Gone
- Mario Andretti
Old 12-21-2005, 12:34 PM
What I learned, I read from pdf Tech manual electrical section -87 944's and from taking a part a spare one I got from a junkyard. I could have made mistakes but this is what I did to get mine to work.
My 924S VDO Tach doesn't have the MPG so I didn't have to worry about the hall sensor signal from the speedo meter on Clutch housing (but I think you could pull that off the DME Harness splice (I think DME 8 (Green) and 27 (Black). Didn't like the upshift light so pulled the bulb on that (although you can pull the Square 2 pin by DME to disable). Also requires signal from Speedo signal.
Tachs Pins:
1- {Black/Yellow Engine} Speed (ignition) wants switched +12V so I jumped it cause I was only getting like 7V for ? reason
2- {Green or Green/Yellow} Injection Signal (wave) (internal connection to HG)
3- {Gray/Blue} Speedo Hall sensor (wave signal)
4- {Gnd Blue/Yellow} Coolant Temp gauge is feed from this pin (I only have a Engine Temp Gauge for now)
5- {Black Switched} +12V Also had to jump, was getting 0V (is internal connection to H+)
6- {Green} Ignition pulse (neg side of coil) Ran new green wire from the 14 pin plug (front driver side firewall) from the one pin (white on 968) to the Tach cause I wasn’t getting the wave signal. Don't Cut old wire! Just splice in a new one on Firewall side of plug pin 1.
Speedometer to Tach:
HG {Green/Red} Hall sensor Pulse (Square wave 1-6 Volts generated by Hall effect on Front left wheel spinning)
H+ {Black Switched} 12V supplied jump on pin 5 and internal VDO connection to H+
I have the old cable coming from the left front wheel and hall sensor for the speedometer so I didn't have to deal with one from the Transmission. I didn't see a plug on the my 968 6speed Tranny anyway, but I remember seeing the 2 DME Pins for it.
I believe it would work basically the same thoe. You would run/splice into the wires from the HG and H+ (loop) to your two pins on the Tranny Speedo. I think it basically provide a voltage potential that is Oscillated by Rev Speed of Axel Gear.
Old 12-22-2005, 10:51 AM
vott does ziss do?
ronin's Avatar
Originally posted by d.a.autry
There's just something about the sleeper though!!!! Ain't nothin' like pullin' up alongside some of the snobs up here in Evergreen and dusting their S8, or C5, or Viper in a ragged out '83 944.
keep dreaming
Old 12-22-2005, 11:24 AM
..P ..P is offline
Wow, very nice job. I'd put a shield around your filter to avoid heat from the radiator, as motors like cold air a lot better.
That car is going to put a FROWN on someone's face, ha ha, when they try to give you a run. I have a S2 and it runs like a bear, but nowhere as fast as what you have.
regards, P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 12-23-2005, 02:16 PM
I'm surprised you aren't using a 968 tranny.
Old 09-10-2007, 11:34 AM
Dave101's Avatar
Send a message via Yahoo to Dave101
Very nice job!!!! Looks awesome! Congratz on getting it done and making your vision come true!
Dave
1984 944 N/A Black (Daily Driver.)
New Users please add your car's year and model to your signature line!
Old 09-10-2007, 12:24 PM
Heres what passion and determination will manifest into. A great example of dedication and hard work. Very nice job.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 09-10-2007, 03:58 PM
pics of spare wheel well modification
Congratulations, this is a great effort!
Do you have any pics available of the modified spare wheel well, from above and below? And any other pics of the 968 tranny in place? I'm thinking of putting a 968 tranny in my 924 Turbo.
Thanks.
Old 05-05-2012, 06:10 PM
Eric
Last post was 5 years ago........
Eric
Old 05-05-2012, 06:49 PM
77 924..clinton twp. mi.
old 924's Avatar
that has to be the nice'est 924 i have ever seen....and i would think much lighter then any 944/968 out there....holy s**t nice job...i will just say poor mustang that ever run's up on you....... that is a work of art...
.(may the porsche be with you)
Old 05-05-2012, 11:45 PM
old 924's Avatar
i had to rap my head around this and read all this again(my 1st time seeing it)...i'll say it again......HOLY S**T...that is the nice'est ....924...(the daddy of them all) ..i've ever seen...you took it from a 1976 body to 1995 powerhouse...OMG do i N.V. you....
Old 05-06-2012, 12:04 AM
True, but still a cool project and we are getting close to swapping 968 running gear into my 924S..
Old 05-06-2012, 09:44 AM
J1NX3D's Avatar
im looking forward to doing this project too. I have had a low km '94 968 6spd since Nov last year.
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 05-07-2012, 02:20 PM
AFM #725
Gawernator's Avatar
old thread but wow.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-07-2012, 03:30 PM
strath44's Avatar
don't remember this at the time nice to see it bumped back from the archives!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 05-08-2012, 02:01 PM
