-   -   Speed/Reference Sensor Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/258643-speed-reference-sensor-question.html)
PhillysMostWntd 12-31-2005 04:09 PM
anyone know what the part number for this is? i cant seem to find any information on it.
while im writing this, i heard a while back about cleaning the auxilary air valve with gunk out (any cleaner i guess) that it will help out in a few areas.. any experience or advise on this one?
JimTR/944 12-31-2005 04:41 PM
Pelican does not list a speed or reference sensor in their on line catalog. I need to get a new reference sensor because a PO destroyed the plug on the end of the sensor and just taped it up. It is no longer mounted in its bracket. Are the reference and speed sonsor the same part number? Do a Yahoo search you will find a speed/reference sensor
JimTR/944
My TR4 and TR6 have gone to bed for the winter so I am driving my 944.
SoCal Driver 12-31-2005 05:16 PM
The sensor plugs don't have to be in the bracket to work. As long as they stay together and not come apart. Agreed they don't look good but at $80 each I'm not too particular.
924Sman 01-01-2006 06:11 AM
944.606.115.00.....if for an 84 na
Carb cleaner....Attach a wire to a DC source and disconnect the plug and hose. 3 pin iirc one grnd, 2 -/+, connect the hot lead to the neg pin and ground then allow the valve to open/close then reverse the polarity, other pin and it returns the valve to the original position. Do this several times until the valve moves freely/smoothly. You should be able to hear it open. Use the cleaner as you work the valve.
SoCal Driver 01-01-2006 09:05 AM
There are three types of idle control valves. The early ones have a heated element that expands and closes the gate valve. Actually a knife valve. The later 944's have an active valve (more of a servo really) that can be driven open and closed by placing one lead on the #2 pin and a lead on either the #1 pin or #3 pin to open and close the valve.
Then there is the third kind that is found on the 944S's and 968's that is kind of a servo and kind of a spring valve. Has a voice/solenoid coil in it that is driven with a variable current that constantly adjusts the air valve against a spring.
All can be cleaned with solvents. Carb and brake cleaner, WD-40, PB Blaster. Just don't dunk it into a carb cleaning tank! No full immersion.
The 924S has the second type as do most of the later 944's. Note this is one of the differences when transplanting a later DME and AFS into an early car. However since the power for the early idle control valve comes off of the fuel pump contacts of the DME relay the wiring to the early DME plug is non existant. Which means you can not use the later idle control valve in the early 944's with out changing the harness. But you can use the AFS and the DME.
