no injector pulse on a 944
I have a 1987 944 I'm getting fuel to the injection rail but no start and will start on starting fluid and I've replaced the dme and fuel pump where do I go from here
Old 01-05-2006, 03:00 PM
SoCal Driver's Avatar
DME relay. Had you come here first we could have saved you the costs of the DME and fuel pump.
List of suspects: DME/fuel pump relay, speed and reference sensors, fuel pressure regulator.
This is how you test:
With the key on check for battery voltage (BV) at the coil and at one of the injectors.
No voltage at the coil = bad ignition switch.
No voltage at the injector but at the coil = bad DME relay.
If both are good proceed.
Lean out of the door with your head down and crank the car. You should hear the fuel pump running for a half second after the cranking stops. If not then check the fuel pump fuse and the DME/fuel pump relay.
If you can hear the pump proceed.
Pull the plug wire off of the front spark plug, stick a spare (used) plug in it, lay it on the intake and crank the car. If there is no spark then check your sensors for loose connectors or broken wires or adjustment.
If you have spark then pull one of the connectors off of one of the injectors and see if you can start and run the car on three cylinders. If you can then it's the fuel pressure regulator or the vacuum lines going to the regulator and damper.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-05-2006, 03:11 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Definitely follow Socals advice rebel.
I am not sure how Socal manages to squeeze all the important elements into a few lines.
If I try and explain it........I just ramble on.......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-05-2006, 08:46 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
that's why he makes the big bucks, alex
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 01-05-2006, 09:29 PM
You say there is no injector pulse. Sounds like a problem with the reference sensor.
Gene
____________
'86 944 NA
'88 Citroën 2CV
Old 01-05-2006, 09:39 PM
