weight reduction
I am looking for info regarding what the lowest weight can be achieved with 944. I am looking at possibly using this particular car for a test mule and don't care what gets thrown out to a degree. As long as it still looks complete from the exterior. Also are there some particularly hefty parts that would possibly be considered expendable, if so what are they?
Thanks in advance Sid
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
The driver
![]() I am not certain. Spare tire and jack are pretty heavy ~40lbs. That and power seats are the heaviest things I've seen removed.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Let's go shooting.
Re: weight reduction
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." Last edited by Dark Skies; 01-11-2006 at 04:15 PM.. |
Custom User Title
lexan hatch would shed a few pounds as well.
Check out the web site for 944 spec racing. They strip their cars to the bones. No rear seats, carpet, window motors, sunroof motors, hatch motors, AC, power steering, etc., etc.
Louie '85 (Early) 944 - Beater '87 924S - Crunch/Rebuild '76 924 - Long Gone "If everything seems under control, you're just not going fast enough." - Mario Andretti |
Non Compos Mentis
Street or track?
You can junk some steel body panels and go with fiberglass or carbon fiber. As said above, strip the interior. Race seats weigh a fraction of factory seats. Don't forget unsprung and rotating weight. Light wheels. Hoosier race tires are much lighter than street tires. |
I do understand the interior and accessory stuff wht I was looking for was like door reenforcements like if it has eccessive carpet padding just any particular items that are really heavy and what the final weight that is generally achieved is?
I am not going to install fibreglass or Lexan. Thanks and I do plan on keeping it on the street just want to lighten areas that are not neccessay and that r not obvious to the naked eye. I will look into some other thread areas for what weight can be attained
power steering rack switched to manual - already mentioned.
air conditioning - already mentioned. spare tire/jack - already mentioned. remove the rear seats. if you still want a "finished" look, then carpet over it.. looks slick IMO... power seats to manual. wheels - fuch wheels are crazy light. remove the sunroof. take out the motor for the power lights in the front - they have a manual crank you can use. smaller battery. remove speakers. rear window wiper. remove the motors in the power windows and leave the arm braces in a fixed position to hold the windows up. remove exhaust/cat and put in straight pipe (provided emission laws dont prohibit it). remove floor mats. remove any sway bars - but i dont think this option is a wise idea. perhaps use smaller ones? there are some i'm missing i'm sure.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Theres also all the sound deadening material on the trunk floor, not that it weighs that much
right..
and on the underside of the hood...
speaking of removing the rear wiper, where do i get a plug for the hole if i take it out?
Writer/Teacher
unsprung weight and rotational mass are porportionately more important to weight reduction than the weight carried on the car's body. For example, every pound unsprung (wheels, tires, brakes) is worth 10 sprung. Weight savings on rotational mass (flywheels, etc.) is exponential.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Let's go shooting.
Just my two pence. I used to drive my road legal race car on the road to get to meets and it was noticeably tiresome on long-ish journeys.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
There's a lot of weight in the exhaust, too. Iron headers in the early cars are 20 lbs heavier than late ones. |
