Send a message via AIM to fmalgapo
How is the Steering Column or spindle grounded? EARLY 944
Trying to diagnose a gremlin horn issue, I notice that when the I attach my momo wheel to my steering column, with the wire supplied with it connected to the horn button and grounded to the hub, the horn will not work, however, with the steering wheel out, if I touch the contacts on surface of the stalk with this wire from the hub, the horn will sound, but not when I touch the steering column itself?
Is there a corroded ground somewhere that I'm missing?
-Frank
'83 944
'10 997.2 Guards Red GT3
Prev: '84 944, '16 M3., '15 STI, '14 500 Abarth, '08 135i
Old 01-12-2006, 12:27 PM
Virginia Rocks!
VaSteve's Avatar
The button is isolated. Look at the back of the momo horn button. The wire coming from the column attaches to that. The wire attached to the momo button (that came with it) should be grounded to the hub. There should be a ring that gets sandwiched between the wheel and the hub, mine was missing (wheel was used) so I made a ring connector and sandwiched it as described. Mine is actually sandwiched between the main hub and the 1" spacer.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-12-2006, 12:44 PM
Thanks VaSteve,
Had same issue on my list to solve.
Did Notice there was also a short Ground (Green) wire from base of steering Rack to Cross Member.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 01-12-2006, 01:22 PM
