iobound's Avatar
Send a message via AIM to iobound
Need thread: 944S engine into 944
I'm buying a 944S motor from one of the members of this board.
THANK YOU pelicaners!
My question is, I have a 1988 NA which will take the 1987 944S motor. I'm getting everything with the 'S' motor from the exhaust headers to the airbox. How tough is this swap. Does anyone know of a thread or maybe a URL or a HOWTO for this swap?
Thanks in advance!
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 01-24-2006, 10:29 AM
Burn the fire.
Brando's Avatar
Since I don't know for certain... Look at what it will cost for the DME harness/engine harness and an S DME.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 01-24-2006, 10:57 AM
iobound's Avatar
I'm getting the DME and harness with the 'S' motor.
Thanks!
16 year PCA Member
NASA Member
Old 01-24-2006, 11:32 AM
ae1969's Avatar
Send a message via ICQ to ae1969
No different than swapping my 951 parts into my NA.......... OOOOPSS.... Did I say that out loud.
Pretty straight forward......
Drop Tranny...
Drop engine...
Insert engine
Insert Tranny
Start the car.
You should not have any issues with those two.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-24-2006, 12:15 PM
SoCal Driver's Avatar
Don't forget the ignition module. Hope the air filter will fit under the front.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-24-2006, 01:49 PM
Capri22racer's Avatar
I took an extra 944S engine and dropped in to a S2 with a blown engine. Was not just a drop, install and go. But was not bad and can be done.
Main things where wiring. You'll need the 100% COMPLETE wiring harnesses and DME swapped out. The "S" also has an extra little ignition module box (no spark without it). It normally mounts in front of the cruise control motor.
The S uses the same radiator as standard 944, so you'll be fine there - I had re-fab mine a bit with some spacers since the S2 rad was bigger.
The airbox will clear the hood fine. You'll need to mount the airbox so make sure they include the 2 brackets - the S2 shell had the treaded holes in place already - not sure on a standard 944 (look at where the hood hold down latch is, on the passengers side you should see 2 threaded holes not in use - if not, you'll need the drill and tap some.
The other one was wiring the RPM guage. The S might be same as the stanadard 944? The S2 was not - but I did find online reference on how to re-wire it. No biggie.
All was easy - just time consuming doing all the re-wiring. Let me know if you need any of the wiring cross reference stuff and I'll e-mail tham to you. Saved me a ton of time and scratching my head.
Also, I would check/or replace the clutch and do a complete belt job while the motor is out. Would save some money down the road and you would know the correct time to replace them. New engine mounts maybe. Also check the cam chain tensioner, they are known to fail in the S and S2. I hear you can just buy the plastic piece now for around $40 (the part that fails) rather than the whole assembly ($300+)
1980 924 Carrera GT
1991 944S2
1984 944
Old 01-24-2006, 01:52 PM
Custom User Title
Dave L's Avatar
Dont forget to check the cam chain tensioner, I belive the service interval is about 100,000 miles. If you are doing all the work on the install you should replace the tensioner, chain and J tube. Those "S" head's arent cheap.
Old 01-24-2006, 02:12 PM
NO! Don't tell him that!
I need to sell some of these S heads that I have in stock!
Good luck, George Beuselinck
Old 01-24-2006, 03:42 PM
Politically Incorrect
onZedge's Avatar
Originally posted by Capri22racer
I took an extra 944S engine and dropped in to a S2 with a blown engine. Was not just a drop, install and go. But was not bad and can be done. ($300+)
EXTRA 944S motor?? If you have any extra sway bars and mounting hardware laying around please send them to me. I'm in between jobs and have to clip coupons to buy lunch!!
"We were so poor, we couldn't afford to pay attention"
Rodney Dangerfield
Edek
'87 924S
'91 535i
Old 01-24-2006, 09:54 PM
iobound's Avatar
Guys, thanks for the info. I'm sure I'll be calling upon you all again when I get the motor in my garage.
GREAT board!
16 year PCA Member
NASA Member
Old 01-25-2006, 05:52 PM
