unclemikeys2001's Avatar
changing door locks?
Has anyone changed out their door locks? I just put on a used handle that has a different lock/key & cant figure out how to swap the locks so I can use my orig key.
1983 944 5 spd, w/ 1984 n/a motor + countless parts from 3 parts cars over the years.
Old 02-05-2006, 05:45 PM
you have to change the tumbler *before* you install the handle.
Take it off, remove the phillips head screw and swap the tumbler.
Good luck, George Beuselinck
Old 02-05-2006, 05:49 PM
I think there is a screw opposite the key that retains the cylinder. Insert key, remove screw, slide out cylinder, replace with old one, and replace screw. **Use the key to keep the tumblers/very small springs from falling out**
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 02-05-2006, 05:52 PM
OK, I got it. My tumbler was kinda stuck & I didnt want to force it at 1st. All is well now. Thanks!!!!
Old 02-05-2006, 06:49 PM
