-   -   Wipers work only on high. Not relay (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/264876-wipers-work-only-high-not-relay.html)
unclemikeys2001 02-05-2006 04:55 PM
My wipers all of a sudden now only work on the fastest speed. Do not return, or go any slower. I figured it was the relay. Ive parted out 2 other 944s so I had 2 used spare relays here. Tried them both & neither one seemed to have any effect. All did the same thing, only works on high. What else could this be besides the relay? I find it hard to believe that both spare relays I had are also bad. Please help.
NKN84944 02-05-2006 05:01 PM
Sounds like it is a faulty switch to me. Do you have a spare wiper arm and switch to throw in there too ;)
unclemikeys2001 02-05-2006 05:06 PM
I may have an extra arm/switch. Im going to have to dig. I figured on trying that next, will update when I do.
SoCal Driver 02-05-2006 07:33 PM
You may have to take the wiper motor apart and clean the contacts on the large gear. These circular bands are what control the parking. There are berilium copper fingers that ride these contact bands. Can get a bit of grit between them and cause problems.
As to speeds; as noted above it is the switch that controls these.
