Wipers work only on high. Not relay
My wipers all of a sudden now only work on the fastest speed. Do not return, or go any slower. I figured it was the relay. Ive parted out 2 other 944s so I had 2 used spare relays here. Tried them both & neither one seemed to have any effect. All did the same thing, only works on high. What else could this be besides the relay? I find it hard to believe that both spare relays I had are also bad. Please help.
1983 944 5 spd, w/ 1984 n/a motor + countless parts from 3 parts cars over the years. |
Sounds like it is a faulty switch to me. Do you have a spare wiper arm and switch to throw in there too
'84 944, '05 GTO |
I may have an extra arm/switch. Im going to have to dig. I figured on trying that next, will update when I do.
You may have to take the wiper motor apart and clean the contacts on the large gear. These circular bands are what control the parking. There are berilium copper fingers that ride these contact bands. Can get a bit of grit between them and cause problems.
As to speeds; as noted above it is the switch that controls these.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
