TNT25169's Avatar
Send a message via AIM to TNT25169
Unorthodox but it worked
I just wanted to share with you all a pic I had on my phone from when I did my oil pan gasket last summer. It wasn't exactly like the tool Porsche mechanics use to hold an engine up but it worked well for me and I was able to change my gasket sucessfully. Cost me about $20. in the next post....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 02-16-2006, 04:28 PM
TNT25169's Avatar
www.apartabove.com
Old 02-16-2006, 04:30 PM
Eldorado's Avatar
lol
given the material of the bar, and if it'd be strong enough (obviously it was because you did it), that's an ingenius method of holding up an engine!
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 02-16-2006, 05:44 PM
fast924S's Avatar
Send a message via AIM to fast924S
Yea I have the same type of tool that I bought, But it has tree post, One bar that goes accros like in the pic and the other bar goes the other way and they bolt together. SOOOOO much nicer then using a engine puller to hold the engine up. Just Make sure its SAFE, I had a friend die like 5 years ago cus he THOUGHT he had his boat jacked up good. Remember check and triple check everything and have fail safes for fail safes. I always throw 2 jack stands under the car just to make sure I wont get crushed.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-16-2006, 06:03 PM
Back from Beyond
Just like factory tool...but theirs doesn't make use of non-strategic material!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 02-16-2006, 07:22 PM
TNT25169's Avatar
Well, before I climbed under it, I checked it about 16 times and made sure that if anything started to shift and fall, I wasn't in the way. AT first I was scared but it was actually very sturdy, the weight of the engine held the ends in place.
www.apartabove.com
Old 02-16-2006, 07:30 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I used a chain to tie my engine to the rafters, and let it sag ~ 3 inches. This way I could bolt the cross-member back on to it, then jack up the crossmember/engine assembly. It made it really easy. On a friend's car, I used a hand-winch and a nylon strap to hold his engine up. We talked about building a similar rig, but it was really nice to be able to adjust the height of the engine.
Neat idea though. Perhaps some stabilization is required, just incase the 2x4's try to walk out...
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-17-2006, 11:11 AM
Kevin0323's Avatar
That would scare the ***** out of me. I worry even when I put my car up on jack stands.
1985.5 944NA
http://www.kevinswebsite.com/944/
Old 02-20-2006, 12:19 PM
Send a message via Yahoo to wizkid918
i used 2 2x4's on their sides, held fine
Old 02-20-2006, 02:22 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
I did the same as wizkid918 but used adjustable straps (pressure treated 2 x 4's)
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-21-2006, 03:01 PM
