liljon's924S's Avatar
Lightbulb Subwolfer?
Hmmm... Just wondering if anyone has put a subwolfer in the center of the dash in a 924 or early 944? If so where'd you get it and how did you install it?
"I couldn't find the sports car of my dreams, so I built it myself."
-Dr. Ferdinand Porsche
'87 924S Guards Red, 944 turbo bars, 220lb. springs, Restoration Project even though its and original, 72,000 mile car
'93 325is Red, aftermarket rims, pirelli tires, 95,000 miles
Old 03-02-2006, 03:09 PM
Yea, but it's a dry heat
Thats gonna be one small subwoofer. You may be able to put the amp underneath the glove box, your best bet would be to put everything in the rear cargo area though.
I have 2 10in subwoofers in the trunk of my s2 cab
Old 03-02-2006, 04:06 PM
Send a message via AIM to Gear Dog
I'm not sure but the only woofer that could fit would be a 6inch. Maybe a center channel speaker would be a better choice. A woofer up in the dash would cause a lot of rattling eventually.
86 944 some assembly required!
Old 03-02-2006, 04:25 PM
Can I put another 4x6 in there?
Old 03-02-2006, 04:26 PM
Eldorado's Avatar
probably not..
why on earth would you want to? *confused*
what kind of head unit do you own?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-02-2006, 05:38 PM
where do 944 people put their amps? im looking to put in a subwoofer or two in mine and am currently just looking for some ideas.
1984 Porsche 944
Old 03-02-2006, 06:05 PM
earlr85944's Avatar
powered sub, saves room, go boom!
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 03-02-2006, 06:18 PM
i was thinkin maybe construct a box that would screw onto the foldable back seat in which it would sit flush with the rear when open (ppl can sit in the back) and would have the speakers pointed directly towards the back and when the back seat is closed (making it not possible for anyone to sit back there) having the speakers point upwards.
Not sure what kinda speakers would fit there, maybe 8 inch im not sure. Just an idea tho. If 8 inch subwoofers do fit then two would be the least but id try to push for 4
1984 Porsche 944
Old 03-02-2006, 06:24 PM
KLA sub in rear passenger cubby, amp to drive it in the driver's side rear cubby, sounds great
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 03-02-2006, 06:38 PM
I got an 8in in the passenger side rear cubby with the amp in the spare tire hole on the opposite side of where the spare tire mounts so I can still have the spare tire in the car.
Old 03-02-2006, 07:41 PM
As far as a woofer, you woldent want to put one in the Cente There no enclousrer behind there and it would realy produce any bass at all. You can put other speakers in there If you got an early like me in the center of the dash there is a grill that can be removed and you can put a 4x6 in there if you wanted surround sound in the vehicle or like a 5-6 inch screen. Best speaker in that dash would probly be a 4 inch speaker or a 5 1/4 component speaekr with a modified plate
check out the link on my profile you could do somthing like that ( idea)
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 03-03-2006, 11:42 AM
Re: Subwolfer?
Originally posted by liljon's924S
Hmmm... Just wondering if anyone has put a subwolfer in the center of the dash ....
I don't think I'd like being installed in a dash...
Old 03-03-2006, 06:39 PM
Nice set up Jamie! If only I didn't ever have to use my hatch in a functional way I have thought of the cubby route several times myself, and decided that it would be best to use that for extra cu. ft. of box area, and have a bigger sub mount above it (an inverted L shape type configuration). The spare tire well also seems like an attractive way to go.
As far as the center channel/sub idea... I hate it! Why would you want to ruin your stereo sound with a stupid center channel?! The only reason that I would have it hooked up is if I had a DVD player in the car and had a system with a surround sound mode I always thought it would be a cool place to mount a navigation unit or one of those GPS track/speed/acceleration timer thingys.
'84 944, '05 GTO
Old 03-03-2006, 06:54 PM
s928s's Avatar
Here is my set up. Kind of what you were describing. 2 8" Clarion DVC subs bridged to a 150w clarion amp. The cabinet is 8"at the base and tapers to aprox 2.5" at the top. 3 separate chambers and matches the profile of the 2 rear shock towers. It is attached to the back of the rear seat. When the seat folds foreward the box goes with it so you still have the rear storage area of the rear carpet. Also whn folded and you are carrying cargo. It is less likely to jumo over the 1" origonal seat lip !
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 03-04-2006, 07:34 PM
When I get the time to put mine in it's going to take the place of the back seats. I already took them out. It's going to flat at the same level as the trunk area. A sub behind each seat and the amps flush mounted down into the entire thing. Hopefuly I can get it done here in a month or two. I gotta get the sunroof to stop leaking first. The back drivers side leaks a little and it would go right down on top of the amp. I wish those damn seals weren't so ****ing expencive.
If it has wheels or tit's it'll give out problems.
Early 85 944
94 Katana 750
924 Parts Car
Old 03-04-2006, 08:02 PM
What did you do for front speakers?
Dan
1988 Turbo S (Red)
Old 03-04-2006, 08:45 PM
Eldorado's Avatar
s928s, can you give me some plans for something like that? even just a pencil drawing in ms paint would suffice.. just enough to wrap my head around how difficult building something like that would be.
Kyle
Old 03-04-2006, 09:06 PM
Thank's bro it was fun doing it i still gots a ways to go. And been thinking of a different style of box to put in. The one that is in there currently was supose to be painted same color as the car.
And for boxes there is like you said the cubbies on the side welll you could just glass some 10" subs on each corner and set sumthing up were you coudl still remove um to get at the spair. Me i said heck with the spair
Jaime O.
Old 03-04-2006, 10:29 PM
s928s's Avatar
"What did you do for front speakers?"
the frotn seakers are clarion 4x6 and the rear are clarion 5x7, had to modify the opening...
As fo a drawing or template. I started out with a piece of cardboard made a template and then cut is out of MDF..Used the router and sander to round all of the edges over . Glued and screwed it together.
autowerks9
Old 03-05-2006, 04:25 AM
Do you have any pics? I am still using the 4x6 ad it sounds weak.
Dan
1988 Turbo S (Red)
Old 03-05-2006, 04:44 AM
