hughett's Avatar
Sunvisor sags...what should I do?
My 968's sunvisor sags on the hinge and hits me in the head. Can this be fixed?
Harvey
'94 968 Coupe, 6-speed
'88 928 S4, 5-speed
'85 928 S, 5-speed (Sold)
'02 Audi TT Turbo, 6 speed (Sold)
Old 03-04-2006, 08:35 AM
GostRidr's Avatar
Hey Harvey,
My 44S does this too. My lazy response was to take it right out - I don't use it that much anyway. I was thinking though, maybe there is a way to put something in the pocket along the metal rod to hold it in place. Like a wad of cloth or something. Unfortunately, too many other projects to take up the time!
Keep us posted,
Peter
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 03-04-2006, 09:43 AM
I don't know about the later 44s or 968s, but on mine there is a screw on the underside that you can tighten into the metal rod to make it harder to pivot. I am guessing that your (if different) would have to have something similar.
'84 944, '05 GTO
Old 03-04-2006, 12:35 PM
hughett's Avatar
I don't see such a screw...but you've given me an idea. Perhaps the earlier 944 visor will fit. I'd like to tighten up the stock visor if I could though.
Thanks,
Harvey
'88 928 S4, 5-speed
Old 03-04-2006, 12:46 PM
least common denominator
scottmandue's Avatar
I did the same on mine... if it bugs you too much I will trade you my 1984 944 for your 968.
It is possible that our old 944's have had the visors changed out and therefore actually have the newer visors... are you confused yet? I am!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-04-2006, 01:08 PM
91S2's Avatar
I'm also having that problem. I was thinking of whipping up some McGeyver solution when i got a chance... I'd greatly appreciate if you could please keep us updated with your decision and what success you have.
1991 944S2 Guards Red
Old 03-04-2006, 02:53 PM
Now I am really confused... I just looked in the parts catalog, and it states that the sun visors were the same for 77-95! Are you guys 100% positive you don't have the little screw?! It is only visible when the visor is down and is right by the metal support rod.
'84 944, '05 GTO
Old 03-04-2006, 03:35 PM
hughett's Avatar
I'll have to go look. But I don't recall a screw (happens when you get older).
Harvey
'88 928 S4, 5-speed
Old 03-04-2006, 05:06 PM
Burn the fire.
Brando's Avatar
Mine on the '88 don't have an adjustment screw. What I did as a temporary fix was pull the rod part that mounts it to the body out, wrapped it with some aluminum ducting tape and put it back in. Worked well for a little while. The problem is that inside the tortion bar(s) lose their tortion-ness and the plastic humps on the rods get worn down, then it sags. Dealer replacement is $90 IIRC since it's a sealed complete unit.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-04-2006, 05:26 PM
hughett's Avatar
I hope there's a cure cheaper than paying the dealer $90 for a new set!
Harvey
'88 928 S4, 5-speed
Old 03-04-2006, 05:32 PM
I had this problem and bought a good used on on ebay for around $10. Worked out nicely.
Stock 1988 951, TT aero wipers
Old 03-05-2006, 02:52 AM
planeguy67's Avatar
Mine does the same thing. I just stuck a little velcro patch on the corner of the visor and on the headliner. Too small to look bad and it works.
Proud Owner:
1996 C2 Cabriolet (993)
1988 944 SOHC
1998 Ford Ranger XLT (Total P.O.S.)
2005 Specialized Allez Comp 27-speed (yes, it's a bicycle!)
My Porsche page (I know, kinda lame. Just wait until I learn Dreamweaver)
http://members.cox.net/kronowit/porschepage.html
Old 03-05-2006, 04:32 PM
OnTheRun2's Avatar
There should be a small medal clip inside the visor. If you wrap a towel around the visor at the hindge end and squeese it with a pair of pliers it should tighten it.
I'm not sure this will work, but it does wonders on 60's Mustang visors.
Good luck.
(Mae) Red '86 944na- gettting new paint soon.
(Abby) Black '86 944na- new addition to the family.
Old 03-05-2006, 05:55 PM
Burn the fire.
Brando's Avatar
Good luck.
I'll give that a try... As cheap as replacements can be had from board members parting cars out.
Old 03-05-2006, 07:11 PM
hughett's Avatar
When someone tries this would you please post your results? Sounds good. I'm out of town and won't be able to get to it for week. Sounds like it should work. Depends on how it's made inside I guess. In theory, I like the idea.
Harvey
'88 928 S4, 5-speed
Old 03-06-2006, 04:43 AM
Mine did the same thing. I took a tooth pick and shoved in by where the rod goes into the visor and broke it off where it don't show. Problem solved. May take 2 tooth picks
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 03-06-2006, 10:59 PM
Re: Sunvisor sags...what should I do?
Harvey
Victoria's Secret has the solution...
Old 03-06-2006, 11:47 PM
