DME temp sensor
ok i got a dme temp sensor and im changing it in the next few minutes i just have 1 quick question..
are there torque specs for this part?? or just tighten it nice and snug its has the blue top with a fuel injector type fitting for it. if that helps descibe it. |
I changed mine this past weekend, did not use any torque spec...just tightened it nice and snug. I reccommend opening the overflow tank cap to depressurize the system and have a few rags handy. Also make sure you install the new crush washer.
techno, just sent a pm.
I only have a set of 86 ctrl arms, alum but different part #. Regards, RS check with Murph, P S H Porsche Spoken Here Address: 490 Broadway, West Babylon, NY 11704 Phone #: (631) 321-5100 , off of sunrise hwy, he's got a large shop and alot of parts. (and some very cool Porsches) |
How do you know if this sensor needs replacing :confused:
Yea try to change the sensor FAST, cus coolant starts to come out FAST
techno - is it necessary to use a new crush washer, i know that generally on any app. a crush washer needs to be replaced if removed but uh.. i just put the old one on for now, i dont think there will be any problems but maybe i should? some input maybe?
suprisingly only about 1/4 cup of fluid came out when changing it. my old one looks soooo bad, the blue top is now a grayish-greenish-blue, the metal is dark brown. i was happy with how easy this was, like a 30 second install. i wish everything was this easy. |
http://www.clarks-garage.com/shop-manual/elect-19.htm#dme-temp |
| All times are GMT -8. The time now is 05:23 AM. |
