ECU wires & moisture
I am still having troubles with my car not starting when it's cold or wet outside and I'm pretty sure that it has to do with the amount of moisture in my car. When it's sunny out or dry the car starts up easily. I have been trying to seal off every leak and hole that I can think of to keep the water from getting in and I have been parking my car in the sunlight with the windows cracked to try and dry it out.
I have opened my ECU and I do not see any loose connections or anything wrong with the computer as far as solder joints etc. .. but when my car doesn't start a simple tap on the ECU while turning the key will start the car. Sometimes it dies on it's own a few seconds later but I just keep repeating until it starts and stays on. A while back my dad told me that the wires in older cars can sometimes act like a straw when it comes to moisture. Sucking up the water in the air. I wonder if this is the case with the ECU wires since when I look at them they appear moist? (Yes I have checked the battery tray several times and it's sealed very well) I refuse to put a tarp on my car since it's a daily driver and I live in an apartment complex. As a solution to not replacing this expensive ECU what do you guys think of wrapping the wires and the ECU in a thermal or waterproof blanket? How about just wrapping the wires? Is there waterproof electrical tape? (The wires are partially wrapped and exposed in several areas. ) What if I spray WD40 on the wires or some sort of waterproofing spray? Thanks everyone.
1985.5 944NA http://www.kevinswebsite.com/944/ Last edited by Kevin0323; 03-10-2006 at 10:40 AM.. |
The question is; how are the wires getting wet? Find the source of the intrusion and repair it. Phone companies use nitrogen to pressurize their cables forcing out any water.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
They are getting wet from the moisture in the car. I have been trying to seal off every leak and hole that I can think of to keep the water from getting in and I have been parking my car in the sunlight with the windows cracked to try and dry it out.
1985.5 944NA http://www.kevinswebsite.com/944/ |
If nothing else put a car cover on it when it rains until you can seal the leaks.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Common water leaks - battery tray, windshield/door window weatherstripping, sunroof drain tubes, rear spoiler drain tubes.
Most damaging to the DME would be the battery tray leak, as gravity would place the water dead on the computer. If there are no visible leaks, and you aren't parking in a 2ft deep puddle everyday then the question is where is the moisture coming from.... Only place that my 944 has held water before has been in the rear wheel wells. On a hot day, it would be like a sauna. That could surely contribute moisture. Would the DME be more moisture prone than any other part of the car's interior? I doubt it. Maybe you truely do have a water cooled DME.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
I have the plugs from the rear wheel wells removed and the battery tray is sealed very well. No water is getting in through there.
I am slowly fixing the leaks as I go along. Anyway... can anyone give any input on my question? "what do you guys think of wrapping the wires and the ECU in a thermal or waterproof blanket? How about just wrapping the wires? Is there waterproof electrical tape? (The wires are partially wrapped and exposed in several areas. ) What if I spray WD40 on the wires or some sort of waterproofing spray?"
1985.5 944NA http://www.kevinswebsite.com/944/ Last edited by Kevin0323; 03-10-2006 at 02:29 PM.. |
You can do anything you like to the outside of the wires, but if there is a problem, it would be inside of the wires. Even so, I doubt this is it. If the wires were corroded inside, then tapping the DME wouldn't fix the problem
If tapping on the DME fixes the problem, I'd be cleaning the contacts on the wiring connector, and re-soldering the DME. For the connector, use something like De-ox-it, or another de-oxidizer.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
One thing that might be a problem with that would be heat. The DME has to ventilate to get the heat away and heat is a computer's worst enemy. Wires themselves being wet probably don't hurt anything as long as there is insulation between them and a ground or another wire. It's really the water on the bare connectors and circuit boards that is killing you. If I had concerns and I couldn't fix the problem of the leaks, my first thought would be to move the computer to higher ground somewhere on the car but I am guessing it will have to be a place where it can be grounded. But the right answer is still to fix the leaks.
Thanks Razorback1980!
Could the same problem occur if the computer wasn't grounded well enough?
I am guessing that is true, so maybe that is something to try first. So Cal is so much ahead of me on the electrical issues, it would be great if he could comment on the ground, but I'm pretty sure it needs to be well grounded.
Does anyone have a picture or pictures of the computer screwed in and in place exactly how it should be? Maybe my previous owner messed with it and didn't put it in correctly.
*bump
I would even settle for a diagram or a typed description
![]() This is for a 1985.5 by the way.
1985.5 944NA http://www.kevinswebsite.com/944/ Last edited by Kevin0323; 03-13-2006 at 10:46 AM.. |
ok
1985.5 944NA http://www.kevinswebsite.com/944/ Last edited by Kevin0323; 03-14-2006 at 11:40 AM.. |
