PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
O2 sensor
i got a universal bosch o2 sensor a while back, looked closely yesterday and saw i have a 3 wire o2 sensor, the one i have is the single wired one
where can i get a 3 wire o2 for fairly cheap? local store has a universal 3 wire for $73.99 and pelican lists it at $130ish
i need one fast.. putting my 944 together is turning out to be quite the PITA
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 03-14-2006, 02:25 PM
ae1969's Avatar
Send a message via ICQ to ae1969
there is a generic bosch 02 sensor........ that you can get..... 3 wire....
Approximately 30 bucks...
The part number is on this site.............. somewhere............
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-14-2006, 02:33 PM
Check clark's garage then search the part number on google. I got mine from Kragens for about $30-40
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 03-14-2006, 04:06 PM
Just picked one up from some seller on ebay for $30 shipped.
Old 03-15-2006, 02:22 PM
ok so i went to get bosch o2 sensor #13913, it comes with a connector piece, the guy who worked there was hassling me about buying it saying how it might not work, etc. etc. if i do get this (should i?) do i cut the connector off and splice the wires to the factory wires??
the o2 i was looking at, has 3 wires, 2 white and one black. how do i know which wire on the o2 crimps to the factory wire?
is this the suggested replacement route? the o2 was only $30ish so if this will work out ill head down and get it.
Old 03-15-2006, 04:48 PM
Eldorado's Avatar
green goes to black, i believe.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-15-2006, 05:03 PM
what about the other two?
is there some sort of walkthrough of doing this?
or does anyone have instructions or something?
Old 03-15-2006, 06:50 PM
Eldorado's Avatar
if you didn't already know, the only difference between the 3 wire and the 1 wire sensor is that the 3 wire comes with a built in heater, immediately bringing the sensor up to operating temperature instead of needing to wait for the exhaust to heat it up.
the black/green wire carries the signal of the sensor, the other two supply heat to the sensor and go to a powersource coming out of your DME (i believe).
what is on the car currently?
Kyle
Old 03-15-2006, 08:19 PM
the 3 wire is on the car currently which is strange.. i thought i had a 1 wire this whole time
Old 03-15-2006, 08:41 PM
Eldorado's Avatar
ok so you've got it all sorted out then? or are you still having problems trying to figure out what wire goes where?
Kyle
Old 03-15-2006, 08:44 PM
ok let me see
the black wire is for the actual o2 reading, the two white wires are only to heat it up, so it doesnt matter where the two white ones go. black goes to the black one, white ones go to either of the other white ones, the o2 from the store (13913) will work then if i just splice it then right? just making sure, it seems like every part i have im having trouble with.
right?
Old 03-15-2006, 08:55 PM
Eldorado's Avatar
no worries.. that's what forums are for!
I haven't done this myself so please wait until you get confirmation before you do anything... but it's my understanding that you are correct.....
Kyle
Old 03-15-2006, 09:07 PM
ya i wont get a chance to do much until tomorrow anyways, thanks for the help. im so grateful for this forum, i really dont know where i would be without you guys... youve been a great help Eldorado
so for further confirmation then, yay or nay with eldorado?
Old 03-15-2006, 09:21 PM
bump
Old 03-16-2006, 09:52 AM
Back from Beyond
I think Eldorado's right. In fact, if you live in cooler climes it's better to not have the sensor heater working. I've found my car gets grumpy when the O2 sensor heats up before the engine is warm enough to be leaned out.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 03-16-2006, 10:39 AM
Send a message via AIM to hpaulb
Been looking at all the auto parts places in the US and Canada. Can't get one for under $80 except for Ebay. Don't want to spend much just to try. Mine is working but bad mileage so I'm going to try obne and see. There are two 3-wire on ebay at the moment. Bosch and Warner. Both for under $30 Can. including shipping.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 03-20-2006, 10:02 AM
