O2 sensor test resuts
Finally got around to it to see why I only get 270 km/tank fuel economy. Started cold at ~.2vdc. As it warmed it rose to around .6 but then started to quickly fluctuate between .7 and .15. I would think it was switching back and forth between open and closed loop. When it dropped the engine idle increased.
Anyone see this before?
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
This behaviour is as expected. Your O2 sensor is probably OK. The sensor is ment to alternate voltage like that.
Doesn't sound right. A passive device that uses somthing like a crystal to output a small voltage varying on temperature should not jump like that? How would the computer read this and vary the fuel ratio based on somthing jumping all over the map?
My highway fuel mileage has dropped from about 30 to 22-24 range on two tanks. My O2 sensor puts out .55 V when cherry red and takes a long time to drop off when I remove the torch from it. It also takes a long time to reach .55 V when heating up (like almost a minute). I understand 0.55 V is a little on the low side. New one should be in Tuesday so I should know something in two weeks about mileage. Town driving also dropped from 24 to around 19 mpg. Plan to test the new one before putting it in the car.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i Last edited by Lawrence Coppari; 01-29-2006 at 12:38 PM.. |
O2 sensor voltage should vary by a minimim of 0.5v ..in other words from about 0.25 - 0.75v.
Yes, it does and should fluctuate. If it doesn't something is wrong. Usually, if stuck on 0.45v the sensor itself is dead.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Your sensor is working properly.
The "jumping" you see is actually being caused by the DME. The DME "reads" the O2 sensor and adjusts the injector duty cycle (Open/closed times) to that the AVERAGE sensor output corresponds to a fuel/air ratio of 14.7:1. To get a better idea of what is going on, start off with the sensor disconnected from the DME. If you have a late model (85.5 and later), disable the idle stabilizer as well. Once the sensor is up to temperature, with the engine at idle you should see an output in the 0.60 to 0.70 volt DC range. If the voltage is too high or too low, adjust the by-pass on the Air Flow Meter. When you make your adjustments you may need to adjust the idle by-pass on the throttle body to maintain a proper idle RPM. Lawrence: Your "test method" is not correct. The sensor needs to be in the engine exhaust, not the flame from a torch.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
Cliff:
What I did is pretty much a standard method of testing according to numerous sources I have found. Why should one believe you when there is only one of you and countless other sources underwriting the out of vehicle torch test?
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
winter-hater club member
whoah, now, lets keep it friendly.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Just asking a simple question. Why does he think he is correct and many other sources are wrong? Nothing unfriendly, I just want substantiation of his claim that contradicts general thinking.
Do a google search on oxygen sensors, then do a search on results with the word 'testing'. Read the links. My new oxygen sensor arrives today. I'll do the same test with it and post results later.
To test an oxygen sensor, you need to get it good and hot, and expose it to known oxygen concentrations.
You can't do this in your own garage. Using a torch will tell you (if your O2 sensor is perfect) how efficient your torch is, and how much residual O2 is in the exhaust of the torch. Not going to tell you a lot about whether it is good. If your O2 sensor was connected when you got those readings, then it's perfectly healthy. If it was disconnected, I would be checking for vacuum leaks and such that would cause the DME to be constantly adjusting the mixture.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Yeah, physical devices don't pay much attention to opinion poles.
1995 993C4 guards red 1988 944S alpine white |
Got the new sensor in the mail and performed the same test with the torch. Instead of taking about 50+ seconds to reach 0.55 V and being very sluggish reacting to torch movement, the pristine one reaches 0.9 V in about 6 seconds and is fast to react. Old one reacted at a snail's pace.
We shall see about the mileage once I get around to installing it. The torch test certainly tells whether the sensor is dead or not. So I guess in mathematics terms, it is a necessary but not a sufficient condition. I don't think oxygen sensors have been around for 40 years. My '71 Ford did not have one......my '80 Mercedes Roadster was the first car that I owned that had one.
still stirring the pot, i see.
There was one other change made to the engine. I installed a new idle stabilizer valve. Previously, the engine would not idle properly when cold. Plugs were rather sooty/oily but mileage was very good. I replaced the ISV and drove car to Atlanta and back. Mileage was much less but cold idle is fine. Plugs, to my utter chagrin, were no longer sooty/oily and had that nice sandy color. But fuel mileage is now in the toilet. Should find out something this weekend as another trip is planned.
Dude, we are all friends here and if you are going to stick knives in someone's back, I'm not sure anyone wants to read your posts so really, just don't bother. If you want to be kind and helpful, that's different. Read the responses, we can't all be wrong. The problem is you! Lighten up or don't even bother asking for help. Advice here is free and you don't have to take it if you don't want, but don't jump down someone's throat because they are trying to help you. What are you trying to accomplish by shooting bullets at everyone?
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
good lord people. can it, already.
one member says he has a test. great. it's documented elsewhere that this test is valid.. whoopie... then someone else in the school yard comes and tells him his test is wrong... the original member posts his results of a new sensor using his method. big deal?? what is all the fuss about? some people test 9V batteries by licking the terminals. if the test works for the individual, great. If it doesn't work for you - move on. be mature.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
I'm not going to try to lick my coil wire to see if the coil is working. Concept probably works though.
Harvey
'94 968 Coupe, 6-speed '88 928 S4, 5-speed '85 928 S, 5-speed (Sold) '02 Audi TT Turbo, 6 speed (Sold) |
That's like my friend, he was trying to figure out what cylinder wasn't firing on my 951, so he was pulling the plug wires 1 by 1 (At the cap, while the car was running). Somehow he was surprised when he got shocked.....
