hatch struts
how do you tell which hatch strut you need,mine is in the driver side.....is that the left side strut or is it the right if you are looking at the engine from the front?
Left and right is ALWAYS determined by sitting in the driver's (or the passenger's) seat and looking forwards. Therefore USA cars are Left Hand Drive, UK cars are Right Hand Drive. It can sometimes be confusing when working on and looking at the engine. All the manufacturers use the same concept. Porsche (as do others) have different ways of identifying left and right parts.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
thank you sir.........
If one is bad the other is close behind. I'd do em both.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
