Radiator drain plug
I seem to have a small leak around the radiator drain plug. Do these plugs/seals ever go bad? I replaced the coolant, waterpump, seals and belts last summer so I'm wondering if maybe that little plastic plug needs to be replaced as well.
keep your stick on the ice.....
86 944na
burgundy/burgundy
Old 03-22-2006, 06:55 PM
SoCal Driver's Avatar
The plastic "plug" has an o-ring around it that does the sealing. Many try to stop the leak by tightening the plug. Just breaks it off.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-22-2006, 07:28 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Yup, snug is more than enough for those plugs.
If it's been over-tightened in the past, it could have damaged the O-ring. They're cheap to replace, and if you can tell for certain that the plug is leaking, try replacing it.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-23-2006, 11:11 AM
ae1969's Avatar
Send a message via ICQ to ae1969
.......and becarefull............ the radiator can crack if overtightened.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-23-2006, 11:24 AM
