callmethewander's Avatar
oil in air filter housing
doing some routine maintenance i opened my air filter housing to change the filter and found about an ounce or so of engine oil in the corner of the housing, where could that be from and why, anybody know?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-25-2006, 07:14 PM
AFJuvat's Avatar
From teh crankcase breather system.
No Worries
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-25-2006, 07:21 PM
wow, that much oil, well, ok thank-you
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-25-2006, 08:28 PM
Eldorado's Avatar
yea i learned last summer when i replaced my filter that these things burp from time to time.. nothing to worry about
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-25-2006, 08:50 PM
That Guy
Techno Duck's Avatar
Pull the j-boot also and look for heavy oil deposits on the throttle body and inside the j-boot. My car had a ton of oil in these parts and i was burning a huge amount through the exhaust. Two o-rings on the air oil seperator (basically the plastic oil filler tube) dry out and for some reason allow oil to get sucked into the intake through one of the vaccum lines hooked up.
I changed the o-rings and no more oil in the intake and very little burning oil..i went down from about .25 quarts every 300-ish miles to very little oil drop after two tanks.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-25-2006, 09:48 PM
thanx all. Techno, where exactly are these o-rings?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-26-2006, 06:55 AM
That Guy
The air oil seperator is basically the oil fill tube. It connects into the block at two points, the o-rings are on each part that goes in. Its a pain in the ass to get the filler tube off though..requires removal of the intake manifold.
Jon
Old 03-26-2006, 07:01 AM
wow, ok thank-you
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-26-2006, 04:21 PM
Granite 944's Avatar
In my limited experience with this, some oil is to be expected due to age, butt..........Techno Duck is right on, as far as I've seen and done. Vacumn leakage problems. Oil seperator mount O-rings and/or more. Sounds like some maintenance projects are in order.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 03-26-2006, 06:23 PM
That Guy
If you decide to tackle the o-rings, its alot to take off but very straight foward. Remove intake box, AFM, J-boot..etc. Fuel rail, then pull the intake manifold. Some good things to do while you have alll of this apart are all the vacuum hoses connected to the ISV, change the ISV itself, change the DME temp sensor, clean / reseal the fuel injectors and change the heater control valve.
The cost of parts adds up quickly, but all of these things will make your car run infinitley better and even if they dont really need to be changed, depending on mileage should be addressed soon.
Jon
Old 03-26-2006, 06:38 PM
I agree.......butt.......if you do the research, you might save some money on some of these parts IF, you test/clean/check some of these sensors, and ISV along the way. DON"T get in a hurry, plan on spending some time checking, cleaning, and going thru it throughly.......and it really won't be that bad. Just more time, than anything, butt, some money is gonna be involved. Research, and take your time. Good luck!
Old 03-26-2006, 07:07 PM
ok, probably stuff i should do, i'm at 100, 000 mis. and i get a little hesitation under heavy acceleration, sorta like a it's missing only not as bad. I'll make a list from your post and add it to the things i'm already doing, so far; engine mounts, tansaxle fluid, cooling temp switch, dist. cap & rotor, adjust em. brake, hood struts, power steering belt, new radiator (exp. tank) cap, clutch slave cylinder, new timing belts and rollers. So i'm gradually getting to everything i can, right now the most pressing thing is rear rotors and pads
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-26-2006, 07:12 PM
That Guy
In my opinion if your going through the trouble to remove the intake manifold, why clean the ISV when you can just replace the thing? Some have sucess with shooting carb-cleaner in, some dont. Not worth doing a pain in the butt job twice.
Jon
Old 03-26-2006, 08:03 PM
umm...
what's the ISV?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-27-2006, 01:13 PM
That Guy
Idle stabalizer valve
Jon
Old 03-27-2006, 03:25 PM
athankyou
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-27-2006, 05:08 PM
