Aufenbahn's Avatar
Which is worse ( or better
Hi Everyone - This is my first post - I'm looking to get into a 944 and the ones I can afford either have bent valves or a bad ring and pinion/bad tranny. Which would you consider to be worse to work on?
Also - any 944s for sale cheap in the upper midwest?
Andy D.
Currently driving 2005 Audi A4
Currently driving 2006 Ram 1500 sometimes
Old 04-03-2006, 02:51 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Bent valves is better in my opinion.
Look around the southern states, california in particular, lots of cheap ones down there.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 04-03-2006, 02:55 PM
Bad Tranny 2 - 300 for a used one and 2 - 3 hours to install. Really a DIY job
Thrown belt.
Head work or used head
Possible Piston damage
New Timing and Balance belts
5 - 7 hours labor
Or in other words $$$$$ when compared to the Tranny in time and money..
The upside is that the belts would then be done which is important maintenance...
Regards
Graham
Early 85 944
Factory Cold Air Intake
Radial Tires
Old 04-03-2006, 03:07 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Go with what you know. If you know how to work on engines better than you know how to change transmissions, then buy the bent valve one...if it's the other way around, buy one with a bad transmission. Of course it's like Graham said, then you'll have to change the belts. Of course if you don't have mechanic strengths, then you should consider another car.
I also think livewirevoodoo has a great point.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-03-2006, 11:15 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
new (used) engines are cheap and transaxles are cheap. replacing the engine involves dropping the transaxle as well.
think about it
keep the dream alive!
1988 944 NA (purple)
Old 04-03-2006, 11:40 PM
livewirevoodoo's Avatar
I would seriously consider that if your budget only allows purchase of a 944 with some sort of critical damage to it chances are you will be paying more than the cost of the car the first year on maintenance items/replacement parts alone.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 04-04-2006, 04:13 AM
earlr85944's Avatar
worse= bent valves
it could have bent valves plus other problems found after repairing the valves, better to hear the motor run and know that you will be replacing the complete trans as stated above.
If you dont do your own work dont get either though, if you want to start doing your own work, go for it!
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 04-04-2006, 08:30 AM
earlr85944's Avatar
worse= bent valves
83 944....bye bye
Old 04-04-2006, 08:31 AM
