Dtchy's Avatar
Bilstein question
Hi,
I recently installed brand new Bilstein inserts and Weltmeister 250lbs springs on the fron and Bilstein shocks in the rear. However, there seems to be something funny going on. When I come to a full stop, the car wiggles a little bit as if it's not being dampned and just working on the spring. It's pretty annoying actually and it almost seems as if there is a little play in the insert. I don't hear any noises coming from the front.
I do have the right part numbers of both springs and inserts.
Could it be that the spring overpowers the insert?
Has anybody ever experienced this???
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 04-04-2006, 12:58 PM
That could be caused by the tires flexing because the suspension is so stiff. It's a little giggle right?
Early 85 944
Factory Cold Air Intake
Radial Tires
Old 04-04-2006, 02:03 PM
Dtchy's Avatar
Yep, that's what it is. Wow, is that really the tires? Didn't even think about that.
Old 04-04-2006, 02:23 PM
White and Nerdy
Tervuren's Avatar
In simulator's, I know it could indeed be the tires that cause that. Whether its what is doing it for you or not in this case, I don't know.
Shadilay.
Old 04-04-2006, 03:32 PM
meister member
speedracing944's Avatar
you could try playing with your tires pressures to see if the "giggle" changes.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-05-2006, 03:38 AM
When I have race rubber on my giggle goes away. On streets it is there.
Early 85 944
Radial Tires
Old 04-05-2006, 05:58 AM
Dtchy's Avatar
Speedy
Yeah, I think I'm gonna try that. Otherwise I'll live with it...
At least now I know it's supposed to be there and there's no need to take the whole shock apart again...
Old 04-05-2006, 02:53 PM
