Porsche Crest Pop Quiz!
Is there any diffrence between a 944 transmission
and a 924 Transmission?
My guess is that the 924S & the 944 are identical
but the 924 will fit, but has diffrent gearing.
Can anyone verify? I am currently looking for a good
low mileage transmission to fit a 1984 944 close to the
Los Angeles area. The best deal I found was here on this
site in San Diego. If nothing closer pops up I'm heading
south. But I did fing a pretty cheap 924 transmission locally
and I am curious if this will work.
Thanks!!
Old 05-04-2006, 02:06 AM
924RACR's Avatar
Not all 924's are the same - make sure you're looking at a 924S tranny from the 2.5L car. The 2.0L 5-speeds (there's 2 types) may look the same (one doesn't at all), but smaller shaft size as well as different ratios means no go.
Yes, the 924S should swap in OK... not sure the gearing is any different...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 05-04-2006, 05:12 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Just a different 5th gear(desired) is all on the 924S or late 944.
Yep, you don't want the "snailshell" as I believe Vaughan is referring to on the early 924 2.0L.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 05-04-2006, 08:16 AM
SoCal Driver's Avatar
Later transmissions will go into an early car. May have to change/modify the trans mounts. Early trans can go into the 924S as the speedo on both comes off of the left front wheel.
The 924S trans will go into the early and late cars. For the later cars you have to add the speedo take off "gear" behind the left side output shaft.
Gear ratios are another matter altogeather.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-04-2006, 10:11 AM
