Writer/Teacher
Long Blocks/Short Blocks
I will know if I will have the 951 long block within about 2 days or so...
But if I don't end up getting it, would there be any advantage to buying a 951 short block as opposed to just a 944NA short block? I would guess that it is ready to take the lower-compression 951 pistons, but that is just a guess. Along the same line of thought, which do you think would be a preferable buy: a long block which includes the head and cam tower for $500, or a short block for $100?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
well the differenes between the 944 and the 951 blocks are the pistons and the forged rods correct? so... on that info, i would get a 951 block to avoid having to buy new rods. If you can get the long block, do it, because it saves you some time/searching for the other parts to complete the block.
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Writer/Teacher
That's what I figured.
1st choice is still the long block... But if I can't get that, the short block would give me an opportunity to give me a REAL project...
Where are you getting this 951 block from for so cheap.. hook me up with one
winter-hater club member
the early engines had forged rods, IIRC.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Turbo blocks have thicker pistion walls.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Cars & Coffee Killer
What are the differences between a long block and short block?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
a short block is just the block, along with what lies within: pistons, crank, et. a long block is all of the above plus the head, cam, etc.
And I thought there might be a difference in the length of some 944 blocks! D'oh! (I thought they were all the same basic design--except that 2.7 and 3.0 blocks had a larger bore.)
