			 winter-hater club member
				decent cone filter
			i really don't want to start the cone filter debate again.
				i am looking for a source of decent cone filter setups for my turbo. the problem is that the filter housing is destroyed and i don't want to fork out the cash for a new one. i've been looking for a good used one for three years now and i am always too late contacting the seller. so... in the interest of saving a little money, i just want to put a cone filter on there and be done with it. any suggestions? TIA
	2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever  |
			Get a k&N style cone filter that you spary oil onto and make sure you get the kit with the aluminum afm mounting plate. There are 2 kinds. One has a flat piece of steel on the end which is a flow restricter and the other style has an open front to suck in air and that is what I use and would recommend. I had to weld a bracket together to mount my afm to because once the air box is gone there is no mount to speak of other than the J boot.
			is there a vendor you can point me to?
			Hi, here is basically the cone that I run on my 944 na but at 40 delivered just for the cone do some research and you may get one cheaper somewhere else. Ebay 150058157540. Wanted to thank you again for answering the questions that I had on my recently purchased 951S. Ed from Ohio.
			you are very welcome.
			 Trying to work for parts!
			Believe Pelican has them also.
	86 Metallic Grey 85.5 Metallic graphite - Gone  |
			i looked at pelicanparts first, didn't see any.
			I Think I might still have a old adapter plate sitting in my garage, want me to check??
	1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership  |
			yes, please.
			I've got an brand new adapter plate and k/n filter for the turbo.  When I bought it privately I thought it it would fit my NA.  The plate didn't.  So make me an offer on the plate and filter and it's yours.
	83 944na - Gone but not forgotten.  |
			Ahh, I will check today I should be in my garage most of the day getting my motor in.  Only thing is its for a NA, will that work on a turbo???
			i think it will bolt on, but it doesn't have the necessary bracket to attach the AFM to something.  don't sweat it.  i have another pelican member that is checking on a stock airbox.  thanks for looking, though.
			Photo for others.
			thanks, everyone.  i have an airbox on its way.  i should have asked for help two years ago.
